חיפוש מהיר
תכונות המוצר:
נתב אלחוטי בתקן 802.11n עם כניסת FXS ו-4 כניסות LAN
תאור:
SIP- telephony
VoIP- FXS- router has a port that allows you to connect an analog phone to make calls via the Internet.
Wireless Interface
Using Wireless Router DVG-N5402SP, you can quickly arrange high-speed wireless network at home or in the office, providing Internet access to computers and mobile devices almost anywhere (within range of a wireless network.) The Router can serve as a base station for wireless network devices of the standards 802.11b, 802.11g and 802.11n ( up to 300 Mbit / s) . Enable and disable the wireless network router , you can single click WLAN, located on the device .
In the router supports multiple functions for the wireless interface . The device supports several security standards (WEP, WPA/WPA2), filtering devices to be connected to MAC- address , as well as allows you to use WPS, WMM.
In addition, the device is equipped with a button to disable / enable the Wi-Fi- network. In case of need , such as leaving home , you can turn off the router's wireless network at the touch of a button , while the devices connected to the router's ports will remain in the network.
Security
Wireless Router DVG-N5402SP provides firewall . Enhanced security functions minimize threats of hackers and prevent intrusions to your network .
Configuration and צanagement
To manage and configure the wireless router DVG-N5402SP uses a simple and user-friendly web- interface (available in several languages ​) .
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
