תאור
Making phone calls over the Internet for home and office
IP-phone DPH-150SE/F2 allows connection to your DSL / cable modem connection to make inexpensive Internet phone calls. This device combines the advantages of modern technology of Voice over IP with advanced communication features. Phone DPH-150SE/F2 to take advantage of VoIP technology with quality comparable to conventional telephones.
High-quality voice
IP-phone DPH-150SE/F2 supports QoS, which ensures the quality of the transmission and reception of voice, similar to using a regular telephone line. In addition, this phone supports many useful features, including call transfer, caller ID, three-way conference and function of "Speed Dial". All it convenient to dial out or answer phone calls.
Simultaneous search for pages in the Internet and make phone calls
Phone DPH-150SE/F2 has 2 ports Ethernet, one of which is designed to connect to a cable / DSL-modem or a broadband router. The second Ethernet port lets you connect a personal computer. In this case it will be possible to simultaneously talk on IP-phone and search pages on the Internet, send emails, transfer files and perform other network tasks on the computer.
Integrated Safety and Security
DPH-150SE/F2 option supports Voice VLAN, which allows you to isolate and protect the voice traffic is transmitted over the Internet. It also supports traffic prioritization, which provides file transfer and work with Web-sites without sacrificing voice quality for Internet Telephony
מאפיינים כללים
Ports
• WAN: 10/100Base-T with RJ-45 LAN, with support for POE
• LAN: 10/100Base-T with RJ-45 connector for PC
SDRAM
• 128 Mbit / s
Flash
• 32 Mbit / s
Functions
• Supports SIP 2.0 (RFC3261) and associated RFC
• Codecs: G.711 A / U Law, G.723.1, G.729a / b, G.722, G.722.1, G.726
• Echo cancellation: Support G.168, the headset can support 96 ms, Hands-free speakerphone
• Voice quality: VAD - Voice Activity Detection, CNG - the generation of background noise
• Full duplex speakerphone (Hands-free)
• NAT transverse: support STUN client
• SIP - SIP domain authentication of SIP (there is no standard, MD5), server name, DNS, Peer to Peer / IP call
• SIP - SIP 2 lines. You can connect to the server SIP1 and SIP2 simultaneously
• DTMF: SIP info, DTMF Relay, RFC2833
• SIP application: call divert / forwarding / holding / waiting / 3 during a call
• Call Management: Flexible dial map, Hotline, purification rejected calls for a blacklist of certain reject incoming calls, call restriction, do not disturb, caller ID
• Phone book (up to 500 contact names and phone numbers)
• Archive of calls: 100 records for incoming, outgoing and missed calls
• Support for conferencing and voice recording on the SIP-Server
• A choice of 10 tunes and a custom
• Support MWI
• Supports SMS
• The "quick set"
• Support Memo
• Multi-language localization
• Network function
• WAN / LAN: Support Bridge and Router mode
• Supports standard protocol NAT and NAPT
• Support PPPoE for XDSL
• PoE support
• Support for DHCP-Client WAN
• Support for DHCP-server LAN
• Support VLAN (optional: voice vlan / data vlan)
• QoS with DiffServ
• Supports DMZ
• Support VPN (L2TP)
• Support for primary DNS and secondary DNS server
• Support DNS Relay, SNTP-Client, Firewall
• Network services for telnet server: Including ping, trace, telnet client
Maintenance and management
• Support for web, telnet, and keyboard control
• Management with different access rights
• Software update via POST mode
• Software Update via HTTP, FTP or TFTP
• Safe mode provide reliability
• Support avtoinitsializatsii (update or config file)
• Support for system log
