חיפוש מהיר
תכונות המוצר:
טלפון VOIP עם 2 יציאות LAN , תמיכה בשני חשבונות SIP נפרדים
דגם לא מיוצר יותר
תאור:
Making calls over the Internet for home and office
IP-Phone DPH-150S allows connection to DSL / cable modem connection to make inexpensive Internet phone calls.
This device combines the advantages of modern technology of Voice over IP with advanced communication features. Phone DPH-150S takes advantage of VoIP technology with quality comparable to conventional telephones.
High quality voice
IP-Phone DPH-150S supports QoS, which ensures the quality of the transmission and reception of voice, similar to using a regular telephone line.
In addition, this phone supports many useful features such as call transfer, caller ID, three-way conference and function of the "Speed Dial". All it convenient to dial out or answer phone calls.
Simultaneous operation of the Internet and make phone calls
Phone DPH-150S has a 2-port Ethernet, one of which is designed to connect to a cable / DSL-modem or a broadband router.
Another Ethernet port lets you connect a personal computer. In this case, it will be possible simultaneously talk on the IP-phone and search Web pages, send emails, transfer files and perform other network tasks on the computer.
Comprehensive security
DPH-150S supports option Voice VLAN, which allows you to isolate and secure voice traffic sent over the Internet. Also supported the prioritization of traffic, which ensures the transfer of files and work with Web-sites without compromising voice quality for Internet telephony.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
