DIR-620EOL EOS
תאור
USB-port
The router is equipped with a USB-port for connecting the USB-modem with which you can quickly connect to the Internet. In addition, you can connect to USB-port router USB-drive to be used as a network drive, or printer.
Wireless Interface
Using a wireless router DIR-620, you can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to your wireless network virtually anywhere (in the range of a wireless network). A router can act as a base station to connect to a wireless network devices, operating according to the standards 802.11b, 802.11g and 802.11n (at speeds of up to 300 Mbit / s).
The router provides many functions for the wireless interface. The device supports several security standards (WEP, WPA / WPA2), filtering connected devices MAC-based address, and allows the use of the WPS and WMM.
In addition, the device is equipped with a button to switch off / on Wi-Fi-network. In case of need, such as leaving your home, you can turn off the router's wireless network at the touch of a button, the device connected to the LAN-port router will remain in network.1
4-port switch
Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network.
Security
Wireless Router DIR-620 features a built-in firewall. Enhanced security functions minimize threats of hacker attacks, prevent unwanted intrusions into your network and access to unwanted websites for users of your LAN.
Easy setup and update
To set up a wireless router DIR-620 uses a simple and user-friendly web-interface (available in several languages).
Now you can easily update the firmware - the router itself is validated on the server version of the software update D-Link and notifies the user ready to install it.
מאפיינים כללים
