חיפוש מהיר
תכונות המוצר:
נתב אלחוטי בתקן 802.11n עם 4 יציאות רשת קוויות Gigabit, במהירות אלחוטית עד 450Mbps
דגם לא מיוצר יותר
תאור:
High work with dual-band 802.11N standard wireless network technology, and Gigabit
Dual-Band Wireless Router N750 D-Link DIR-835 enables users to check e-mail and search for information on the Internet, using a range of 2.4 GHz, while the 5 GHz frequency band can be used for streaming HD-video and other media content with a smooth, uninterrupted playback. Gigabit ports Router DIR-835 allows users to achieve a peak speed of connection, and dual-band technology supports a range of just two frequencies (2.4 GHz and 5 GHz), providing fast and reliable operation of network connections.
HD Fuel ™ technology and intelligent QoS technology
Support for HD Fuel ™ technology delivers superior quality video and gaming. The use of a relatively free band 5 GHz and an extended technology intellectual quality of service (QoS) provides high quality streaming media data. DIR-835 uses intelligent QoS prioritization for analyzing and sharing data streams into multiple traffic wireless and wired networks, resulting in a priority may be applications such as VoIP, streaming video and games online.
Share a multifunction device or usb-storage devices
With utility SharePort Plus Network USB, users can share print, scan and fax in the office or at home, simply connect the multi-function USB-device. In addition, users can connect a USB hard drive to create a shared space for computers and devices on the network, which allows to share photos, documents and media files at home or office.
IPv6 Ready
The DIR-835 supports standard IPv6 and provides compatibility with IPv6 from other manufacturers. This allows you to use 128-bit addressing system and connect directly to a user anywhere in the world with a unique IP-address. This router can simultaneously support routing for networks based on IPv4 and IPv6, which provides full compatibility and the device meets the requirements of today and tomorrow.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
