חיפוש מהיר
תכונות המוצר:
מתאם אלחוטי לנייח בתקן 802.11g במהירות עד 56Mbps.
דגם לא מיוצר יותר
מאפיינים כללים:
Technical Specifications
Standards
IEEE 802.11g
IEEE 802.11b
Interface
32-bit PCI
Wireless Signal Rates* With Automatic Fallback
54, 48, 36, 24, 18, 12, 11, 9, 6, 5.5, 2, & 1Mbps
Frequency Range
2.4GHz to 2.462GHz
Wireless Transmit Power
13dBm ± 2dBm
Modulation Technology
Orthogonal Frequency Division Multiplexing (OFDM)
Complementary Code Keying (CCK)
Internal Antenna Type
Dipole with Detachable Reverse SMA Connector
Security
64/128-bit WEP
Wi-Fi Protected Access (WPA)
Led
Link
Activity
Certifications
FCC
Operating Temperature
32°F to 131°F (0°C to 55°C)
Operating Humidity
90% Maximum (Non-condensing)
Dimensions
Item (WxDxH): 0.8” x 4.8” x 4.8”
Packaging (WxDxH): 6.8” x 9.5” x 1.5”
Weight
Item: 0.3 lbs
Packaging: 0.9lbs
Warranty
2 Year
Minimum System Requirements
Computer with:
Windows® XP SP2 or Windows 2000 SP4***
CD-ROM Drive
20MB Hard Disk Space
32-Bit PCI Slot
Package Contents
Wireless G Desktop Adapter
Detachable Antenna
Low Profile Mounting Bracket
Quick Installation Guide
CD-ROM**** with:
Drivers
Product Documentation
Special Offers
* Maximum wireless signal rate derived from IEEE Standard 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
