DSL-2640U/RA/U1AEOL
מודם-נתב +ADSL/ADSL2/ADSL2 אלחוטי בתקן 802.11N (עד 150Mbps) בעל 4 יציאת רשת
תאור
ADSL- port and 4- port switch
ADSL- router has a port for connecting to ADSL- line. Built-in 4 - port switch allows you to connect computers equipped with Ethernet- adapters , game consoles and other devices to your network . In addition, any Ethernet- port devices can be used to connect to a dedicated Ethernet- line.
Wireless Interface
You can quickly create a wireless network at home or in the office , which will allow your employees or members of your family to connect to a wireless network almost anywhere (within range of a wireless network.) The Router can serve as an access point to connect to the wireless network devices of the standards 802.11b, 802.11g and 802.11n.
The device supports several security standards (WEP, WPA/WPA2), filtering devices to be connected to MAC- address , and allows the use of technology WPS.
In addition, the device is equipped with a button to disable / enable the Wi-Fi- network. In case of need , such as leaving home , you can turn off the router's wireless network at the touch of a button, while
devices connected to the LAN- ports on the router will remain in the network.
Security
Wireless Router DSL-2640U has a built- in firewall. Enhanced security functions minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network .
Easy setup and update
To configure the DSL-2640U uses a simple and user-friendly web- interface ( available in several languages ​​) . Now you can easily upgrade the firmware - the router itself is a proven version of the software update server D-Link , and notifies the user ready to install it.
מאפיינים כללים
Interfaces
• ADSL: 1 port with an RJ- 11
• LAN: 4-port 10/100BASE-TX Ethernet with RJ- 45 auto-sensing polarity MDI / MDIX
• WLAN: built-in wireless interface standard 802.11b, g and n
Frequency band
• 2412 ~ 2484 MHz
Data transfer rate
• 802.11b: 11 , 5.5, 2, 1 Mbit / c
• 802.11g: 54, 48, 36, 24 , 18, 12 , 9, 6 Mbit / s
• 802.11n
  ◦ HT20: 150, 130 , 117 , 104 , 78 , 52 , 39 , 26 , 13 Mbit / s
  ◦ HT40: 150, 130 , 117 , 104 , 78 , 52 , 39 , 26 , 13 Mbit / c
Transmitter output power
• 802.11b: 16,5 ~ 18,5 dBm
• 802.11g: 13,5 ~ 16,5 dBm
• 802.11n: 13,5 ~ 16,5 dBm
Modulation schemes
• 802.11b: CCK ( 11, 5.5 Mbit / c), DQPSK ( 2 Mbit / c), DBPSK ( 1 Mbit / c), DSSS
• 802.11g: PSK / CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK, 16QAM, 64QAM
• 802.11n: PSK / CCK, DBPSK, DQPSK, OFDM , etc.
ADSL Standards
• ADSL: Multi-mode, ANSI T1.413 Issue 2 , ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G . hs)
• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A / L / M, ITU-T G.992.4 (G.lite.bis) Annex A
• ADSL2 +: ITU-T G.992.5 Annex A / L / M
Types of WAN- connection
• ADSL
  ◦ PPPoE
  ◦ PPPoA
  ◦ IPoA
  ◦ Static IP
  ◦ Dynamic IP
  ◦ Bridge
• Ethernet
  ◦ PPPoE
  ◦ Static IP
  ◦ Dynamic IP
  ◦ Bridge
Wireless network
• Standard IEEE 802.11n, device compatibility standard IEEE 802.11b / g
• WEP- encryption
• WPA/WPA2 encryption technology mechanisms TKIP, AES and TKIP + AES
• Access to a wireless network based on the MAC- address
• The PBC method of WPS
• Management of the connected devices
• Advanced Settings
Protocols ATM / PPP
• Ethernet encapsulation bridging and routing
• Multiplexing based VC / LLC
• ATM Forum UNI3.1/4.0 PVC ( up to 8 PVC)
• ATM Adaptation Layer Type 5 (AAL5)
• Principles and functions OAM ITU-T I.610, including F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2,364 )
• PPP over Ethernet (PPPoE)
• Support for Keep-alive for PPP- protocol
Network Protocols and Features
• DHCP-server/klient/relay
• DNS relay
• Dynamic DNS
• Static IP- routing
• Remote access
• Network statistics for each interface
• IGMP Proxy
• IGMP snooping
• RIP
• UPnP
• VLAN support
• Supports ping from the external network (WAN ping respond)
• Support for SIP
• Support for RTSP
Firewall and Access Control
• IP- filters
• MAC- filter
• URL- Filter
• DMZ- zone
• The protection and ARP- DDoS-attacks
• Virtual servers
QoS
• Grouping interfaces
• Priority VLAN (802.1p)
Configuration and Management
• Web- based interface for configuration and management of multiple languages
• Access via TELNET
• Upgrade the firmware of the router through the web- interface
• Automatic notification when a new software version
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP- server and manually configure the date and time
• Ping
Indicators
• POWER
• DSL
• INTERNET
• WLAN
• LAN 1-4
• WPS
תקנים
הורדות
איורים
DSL-2640U/RA/U1AU2
מראה מאחורה
מראה מימין
מראה מקדימה
DSL-2640U/RA/U1AU1
מראה מימין
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
