חיפוש מהיר
תכונות המוצר:
ערכה המורכבת משני מתאמים Powerline AV+ DHP-308AV
תאור:
Starter kit Mini Adapter Powerline AV + DHP-309AV HomePlug AV compliant and uses existing home electrical wiring to create a network or extend an existing network.1 This adapter is connected to a power outlet, allows you to access digital media devices, game consoles, print servers, computers and network storage devices throughout your home. Starter Kit Powerline AV + DHP-309AV includes two mini-adapter DHP-308AV, allowing you to create a home network Powerline.
Powerline AV + technology for applications that require high bandwidth
Powerline AV + technology enables data transmission at speeds of over 200 Mbit / s, ie at a higher speed than conventional devices Powerline AV. This makes the device an ideal solution for applications that require high bandwidth, which guarantee the streaming of HD video, the work of VoIP-telephony, online gaming, without delay. DHP-309AV provides high bandwidth, allowing users of technology "digital home" use existing electrical wiring for high quality streaming media.
Easy Setup and Security
DHP-309AV plugs directly into a power outlet and does not require any special cables. Expand your home network by connecting multiple devices from the most distant points of the house, or create additional connection by connecting a switch or wireless access point to the adapter. For ease of installation the encryption key can be quickly configured with a button press. The adapter supports 128-bit AES encryption to protect your network from unauthorized connection to the line. Thanks to easy installation Plug-and-Play, Adapter DHP-309AV is an ideal solution to create a home network.
Energy-saving function
DHP-309AV supports power saving mode to meet the European directive on the use of energy-using products (EuP). If within a period of time not being transmitted or received, the adapter automatically switches to standby mode, reducing power consumption by more than 70%, and providing automatic energy savings without sacrificing performance.
QoS
QoS mechanism analyzes and shares the DHP-309AV traffic into multiple data streams. This provides HD streaming video, IP-TV work (IPTV) and online gaming without delay, since priority is given to automatic data streams, the most demanding quality of service.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
