תאור
The D-Link DUB-CR200 is a high-speed 3-port USB 2.0 hub with an 8-in-1 card reader. With true plug and play capabilities, you can add three additional USB ports to connect devices such as mice, keyboards, PDAs, and storage devices. It supports high-speed data transfer rates of up to 480Mbps* and remains backward compatible with USB 1.1, allowing you easily integrate all your existing USB peripherals into your home or office network.
The 8-in-1 card reader provides an ideal solution for those who want the convenience to access and store media to the most popular memory cards including Secure Digital (SD), Multi Media Card (MMC), Compact Flash (CF Type I &II), IBM Micro Drive, Smart Media (SM), Memory Stick (MS), and Memory Stick Pro (MS Pro). Using an optional utility for Windows®, each card slot on the DUB-CR200 is identified under My Computer with an icon displaying its name.
The DUB-CR200 also acts as a common data exchange point to instantly transfer large amounts of data to and from attached memory cards, USB storage devices, and folders on your computer. Easily copy favorite photos onto a memory card and share with friends and family. And best of all, transfer documents to a portable drive or memory card and take it with you on the go.
Configured directly by the operating system, the DUB-CR200 operates seamlessly with both Microsoft Windows® and Apple Macintosh® operating systems. Diagnostic LEDs provide activity status for each USB port and card slot. The portable and lightweight design of the DUB-CR200 makes it ideal for travel and easy to store. Enjoy instant access to all your USB peripherals and memory cards with the DUB-CR200!
מאפיינים כללים
• Connect up to 3 USB Peripherals
• Supports 8 Types of Memory Cards
• Hot-Swappable for Plug & Play Convenience
