חיפוש מהיר
תכונות המוצר:
שרת NVR עם מקום ל 2 דיסקים ותמיכה ב mydlink
תאור:
Convenient and reliable video recording
NVR DNR-322L - a stand-alone storage device that can record video with a few (nine) cameras on the selected hard drive space, eliminating the need to turn on the computer. Thanks to technology mydlink DNR-322L provides remote monitoring and playback via Web-browser to the site mydlink or Web-based NVR. Video DNR-322L can continue to record video, while the user browses or searches for the video. Through a set of video management functions DNR-322L is a convenient and effective solution.
Multifunctional CCTV
The users have a wide range of options for viewing and organizing video on the screen. In a system with multiple channels, users can use the mouse to move the selected camera in the viewing area. The names of cameras and recording status are displayed on the screen. You can view video from a camera in full screen mode with a two-way transmission of sound. Users can control the functions of PTZ (pan / tilt / zoom), using the buttons interface or by directly clicking on the video.
Secure storage of data
Administrators can filter the external connections to the NVR for IP-address, restricting access and thereby improving safety. Administrators can also assign access rights for users by selecting the camera, which will be allowed access. Periodically or when necessary, you can save the recorded data on the additional storage device. NVR also supports an option to protect data using RAID 1 configuration, which doubles the data recorded on two different disk. In the event of failure of one of the hard drive stores data on the second disk. Also, a second hard drive can be activated by a file server and installed on a Windows system as a network drive.
Enhanced video
Intuitive interface DNR-322L lets you easily customize options such as compression codec, resolution and frame rate for all connected cameras. After installing the cameras can perform continuous recording or recording on a schedule specified by the user. NVR also provides a record on the basis of certain triggering events, such as motion detection.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
