חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת (Dome) מהירה עם זום אופטי x30
דגם לא מיוצר יותר
מאפיינים כללים:
Camera specifications
• Sensor 1/4 "EX-View CCD
• Optical Zoom: 30X
• Focal length 3.4 ~ 102 mm
• Viewing Angle (Horizontal): 2.2 ° ~ 60.8 °
• Digital Zoom: 12 X
• Day / Night: ICR
• 0.1 Lux (color); 0.01 Lux (B / W)
• 540 TVL
• Electronic shutter speed 1/1 sec ~ 1/10K
• Automatic Gain Control (AGC)
• Manual / Auto Focus (AF)
• Manual / Auto Exposure (AE)
• Manual / automatic white balance (AWB)
• Back Light Compensation (BLC)
• Wide Dynamic Range (WDR)
Codec support
• JPEG for static images
• MPEG4/MJPEG dual format compression
Video resolution
Support for NTSC:
• Up to 30 fps at 176 x 120
• Up to 30 fps at 352 x 240
• Up to 30 fps at 720 x 480 resolution
Support for PAL:
• Up to 25 fps at 176 x 144
• Up to 25 fps at 352 x 288
• Up to 25 fps at 720 x 576
Video features
• Custom size and quality
• Time stamp and text overlay
• Adjustable motion detection windows
Speed ​​transmission of video
• Up to 3 Mbit / s
Network protocol support
I• Pv4, ARP, TCP / IP, UDP, ICMP, DHCP-Client, NTP-Client, DNS-Client, DDNS-client, SMTP-client, FTP-client, HTTP-server, PPPoE, UPnP
Built-in network interface
• 10/100BASE-TX Ethernet port
LAN
• Compliance with IEEE 802.3
• Compliance with IEEE 802.3u
• Full-duplex mode of operation
• 802.3x access control for full duplex operation
I / O port
• 8 input sensor alarm
• a sensor alarm output
Camera
• 360 °
• The slope of -10 ° ~ 190 ° C.
• The desired accuracy of the tilt / rotation of 0.225 °
• Set speed pan / tilt 5 ° ~ 400 ° C.
• 4 preset destinations
• 4 preset auto-rotate
• 8 consecutive presets
• 16 private masks
• Mirroring
• Built-in heater and fan
• Standard IP66
• Protection against vandalism
Monitoring functions
• Remote management / control of 32 cameras
• View up to 32 cameras on one screen
• Management features via web-interface
• Reliable detection of movement or manual entry
Remote management
• Setting up a web-browser
• Creating and maintaining fast pictures / videos via web-browser
System requirements
• Operating System: Microsoft Windows 2000, XP, Vista
• Brauzerr: Internet Explorer 6.0 or higher
נתונים פיזיים
Weight
• 2.6 kg
Power
• 24 VAC
Power consumption
• Maximum of 65 W (with heating)
Operating temperature
• From -40 ° to 50 ° C
Storage temperature
• From -20 ° to 70 ° C
Operating humidity
• From 20% to 80% noncondensing
Certificates
• FCC
• CE
• RoHS
Accessories for mounting
(not included in the camera kit)
DCS-80-5 / DCS-80-6
• Size: 187 x 147 x 76 mm
• Mounting surface: 187 x 147 mm
• Weight: 2 kg
DCS-32-1
• Height: 250 mm
• Diameter: 50 mm
• Weight: 1 kg
DCS-32-2
• Height: 500 mm
• Diameter: 50 mm
• Weight: 1.8 kg
DCS-32-3
• Dimensions: 348 X 104 X 138.6 mm
• Diameter: 45 mm
• Weight: 1.5 kg
DCS-32-4
• Dimensions: 204 x 124 x 135.2 mm
• Diameter: 44.5 mm
• Weight: 1.2 kg
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
