חיפוש מהיר
תכונות המוצר:
מודם/פקס 56K V.92/V.90 PCI
תאור:
Modem DFM-562I - a high-performance analog modem 56 Kbit / s standard V.92/V.90 without the hardware controller, designed for desktop computers. It is installed into a PCI slot and connect your computer to a telephone line, providing home users and small office users to access the Internet through a switched telephone line.
High performance
The modem includes many built-in components designed to perform most of the communication functions. Located on the motherboard controllers offload the CPU computer, assuming the implementation of many of the functions from the CPU implementation which requires regular software modem.
Cost-effective connection to the Internet
DFM-562I modem plugs into any telephone wall jack, the device playing the role of the dial at the request of the computer. This inexpensive device allows home users to surf the Internet or work e-mail without using an expensive DSL or cable modem connection or ISDN.
Data & Fax
In addition to communications software that is compatible with AT commands, DFM-562I modem to send and receive faxes at speeds up to 14.4 kbit / s. The modem implements a data compression and error correction V.42bis and MNP 2-4 for fast and reliable transmission / reception of data.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
