DGS-3000-24TCEOL EOS
מתג מנוהל עם 20 פורטים במהירות ג'יגהביט, ארבע יציאות משולבות ג'יגהביט/אופטי (SFP)
תאור
Gigabit Switch DGS-3000 Series is a line of managed switches D-Link Layer 2 and are intended for use in networks Metro Ethernet. DGS-3000-26TC equipped with two ports of 10G SFP +, which guarantees high performance gigabit aggregation of a large number of compounds. Switches DGS-3000 series are made in a 1U and suitable for desktop installation or for installation in the telecommunications closet. DGS-3000-10TC made in a more compact 9-inch housing that provides better air circulation in the confined space of the telecommunication closet and simplifies cabling infrastructure. Provided for in the DGS-3000-26TC port Alarm allows you to connect external alarm devices to detect potential threats, such as opening doors or overheating in the closet, which is triggered off an alarm. This functionality is very useful for devices used in urban networks and provider networks.
Reliability
All Ethernet-ports switches DGS-3000 series are equipped with built-in protection against static electricity to 6 kV, allowing the device to protect against power surges, especially if the cables are Ethernet-located in an open space or in old buildings. In the event of power failures in the switches, an additional connector for redundant power supply DPS-200 or a DC power supply with a voltage of 12 V. For failover Ethernet-channel devices supports protocol 802.1D Spanning Tree (STP), 802.1w Rapid Spanning Tree (RSTP) and 802.1s Multiple Spanning Tree (MSTP), the use of which allows you to automatically backup data path. Using this functionality allows the transmission and reception of frames even when faults occur in the network. The switches also support Ethernet Ring Protection Switching (ERPS, ITU-T G.8032), whereby the recovery operation after a failure of the ring does not exceed 50 ms. Using detection loops Loopback Detection (LBD) prevents overloading at uncontrolled network segments administered by subscribers or constructed on the basis of unmanaged switches. In addition, the series switches DGS-3000 supports port aggregation functionality of standards-based 802.1AX and 802.3ad, the use of which allows you to combine multiple ports into a group, while increasing bandwidth and improving the fault-tolerant connections to ensure smooth operation and load balancing across multiple network devices .
Triple Play Service
The series switches DGS-3000 is a wide set of functions Layer 2 multicast, including IGMP / MLD Snooping, Fast Leave, and filtering. Support for this functionality provides the ability to work with IPTV-services that are gaining popularity with each passing year and are increasingly in demand in the market. Application features IGMP / MLD Snooping allows host-based connection of multiple IPTV-subscribers to one network interface. When you use the ISM VLAN multicast transmission is performed in a separate VLAN, which promotes effective spending of bandwidth. ISM VLAN profiles allow users to quickly and easily assign or change the preset settings for ports multicast subscribers. Support for IGMP Authentication eliminates the possibility of unauthorized IPTV-subscription due to conduct authentication set-top boxes.
Switches DGS-3000 series support the advanced functionality of QoS (Quality of Service) to provide quality service Triple Play. Packet classification is based on various header fields or user-defined packet content, allowing traffic prioritization. The use of markers "Two speed, three-colored marking" and "One speed three color labeling" (trTCM / srTCM) allows you to classify traffic to maximize bandwidth for priority traffic. By using the bandwidth management providers will be able to determine the level of bandwidth of incoming / outgoing channel per port increments up to 64 kbit / s.
Ease of maintenance, efficient troubleshooting
Implemented in the switches support extended functionality OAM (Operation, Administration and Management) can significantly simplify maintenance, and troubleshooting. By using the diagnostics cable, you can remotely monitor the status of Ethernet-cable and determine the location of a fault, allowing the provider to reduce the maintenance costs of the equipment. Function Connectivity Fault Management (CFM, IEEE 802.1ag) is designed for monitoring and troubleshooting in End-To-End Ethernet-networks, giving service providers the ability to perform the connection test to isolate the problematic segments of the network and identify the users of such segments. Technology D-Link Unidirectional Link Detection (DULD) allows you to track the problem of fiber optic connections, and thereby improve the stability of the cable infrastructure networks MAN (Metropolitan Area Network).
High level of safety and efficiency
The series switches DGS-3000 provides advanced functionality of user authentication / devices, including 802.1X, Access Control Web-based interface (WAC) ² and MAC-address (MAC). Options WAC² and MAC allows network administrators to authenticate the user / device and manage the security of the network without the need to install client software, which is very important if the software is installed on the equipment of the customer is not possible. Also switches DGS-3000 series support the functional Compound Authentication², giving network administrators a choice of several methods of authentication for a single device. Host-based authentication provides precise control access to each device on the network. For integration with billing systems and services supports protocols RADIUS and TACACS. Provided for in DGS-3000 Series feature IP-MAC-Port Binding (IMPB) provides strong binding to the addresses and interfaces, and ARP Spoofing Prevention - protects the network from attacks such as Man-In-The-Middle and ARP Spoofing.
To ensure the smooth operation of the network switches DGS-3000 series has a mechanism D-Link Safeguard Engine to protect the CPU from malicious broadcast traffic congestion caused by viral activity. The switches also support DHCP Screening, provides filtering DHCP-requests from unauthorized DHCP-servers or routers. Application protection functions BPDU / DoS-attacks and filtering L3 Control Packet Filtering allows you to increase the level of network security.
Support for IPv6
The DGS-3000 Series supports functional IPv6, including MLD Snooping, WAC², IPv6 ACL / QoS and IMPBv6, which promotes easy equipment integration in next-generation networks. In addition, this series supports both protocol stacks IPv4 / v6, allowing the switches to act as a bridge between IPv4 and IPv6. All models DGS-3000 successfully passed the certification IPv6 Logo Phase 2, which proves their full conformance and interoperability when using IPv6-networks.
מאפיינים כללים
Ports
• 20 ports of 10/100 / 1000BASE-T
• 4 Combo 10/100 / 1000BASE-T / SFP
Reserve power supply
• DPS-200 3
Console port
• RJ-45
Performance
• Switching Matrix: 48 Gbit / s
• Speed ​​forwarding 64-byte packets: 35,71 Mpps
• MAC-address table: 16K entries
• DRAM to CPU: 128 MB
• Packet Buffer: 1.5 MB
• Flash-Memory: 32 MB
• Jumbo-frame: 12.288 Bytes
Software features
• Virtual Stacking:
  - Technology D-Link Single IP Management (SIM)
  - Up to 32 devices in a virtual stack
L2 Features
• Flow control:
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Jumbo-frame up to 12 Kbytes
• Spanning Tree Protocols:
  - 802.1D STP
  - 802.1w RSTP
  - 802.1w MSTP
  - BPDU Filtering
  - Root Restriction
• The Loopback Detection
• Link Aggregation:
  - Supports standards 802.1AX and 802.3ad: Max. Number of groups - 12, 8 ports per group
• Port mirroring:
  - Supports 1 Mirroring group
  - One-to-One, Many-to-One, through flow (ACL)
• Ethernet Ring Protection Switching (ERPS)
• Layer 2 Tunneling Protocol (L2PT)
Multicast Layer 2
• IGMP Snooping:
  - IGMP v1 / v2 / v3 Snooping
  - Support for 1024 IGMP-groups
  - Fast Leave port-based / node
  - Function Report Suppression
• IGMP Authentication
• IGMP / MLD Proxy Reporting
• Limit multicast on IP-addresses (IGMP-filtering)
• MLD Snooping:
  - MLD v1 / v2 Snooping
  - Supports up to 1024 groups
  - Fast Leave-based site
VLAN
• Group VLAN:
  - Max. 4094 VLAN groups
  - VLAN-based port
  - VLAN MAC-based address (MAC-Based)
• GVRP
  - Supports up to 255 dynamic VLAN groups
• 802.1v Protocol VLAN
• 802.1Q Tagged VLAN
• Double VLAN (Q-in-Q)
  - Port-based Q-in-Q
  - Selective Q-in-Q
• ISM VLAN
• VLAN Translation
• Voice VLAN
• VLAN Trunking
• Asymmetric VLAN
Function level 3
• Support for 1024 ARP entries
• Gratuitous ARP
• The default route
Quality of service (QoS)
• 8 queues per port
• DSCP
• 802.1p
• Bandwidth management:
  - Based on the port (incoming / outgoing, min. Step up to 64 kbit / s)
  - On the basis of the flow (incoming / outgoing, min. Step up to 64 kbit / s)
  - For the output queue (min. Step up to 64 kbit / s)
• Mechanisms for queuing:
  - Strict Priority Queue (SPQ)
  - Weighted Round Robin (WRR)
  - Deficit Round Robin (DRR)
  - Strict + WRR
• Support for the following streams:
  - Tagging 802.1p priority
  - Tagging priority TOS / DSCP
• QoS based on time
• Three-color marking
  - TrTCM
  - SrTCM
• CoS based on:
  - 802.1p Priority Queues
  - VLAN ID
  - MAC-address
  - Ether type
  - IPv4 / v6-address
  - Class IPv6 traffic
  - IPv6 flow label
  - DSCP
  - The type of protocol
  - TCP / UDP-port
  - Contents of the package, user-defined
Access Control Lists (ACL)
• ACL on the basis of:
  - Port Switch
  - 802.1p priority
  - VLAN ID
  - MAC-address
  - Ether Type
  - IPv4 / v6-address
  - IPv6 flow label
  - DSCP
  - Non-TCP / UDP-port
• Support for up to 1,024 access rules
• ACL on the basis of the time
• ACL statistics
• CPU Interface Filtering
Security
• SSH v1 / v2
• SSL v1 / v2 / v3
• Port Security
  - Up to 64 MAC-addresses per port
• Protection against broadcast / multi-address / unicast storm
• IP-MAC-Port Binding (IMPB):
  - Checking the ARP-packets
  - Check the IP-packet
  - DHCP Snooping
• Traffic Segmentation
• D-Link Safeguard Engine
• L3 Control Packet Filtering
• Filtering NetBIOS / NetBEUI
• DHCP Server Screening
• Filtering DHCP-enabled clients
• Prevention of ARP Spoofing Attacks
• Protection against attacks BPDU
• Prevention of DoS attacks
AAA
• 802.1X:
  - Access control based on port
  - Based Access Control Node
  - Dynamic VLAN assignment
• Access Control MAC-based (MAC):
• Access control based on Web (WAC) 2
• Access control based on the Japanese Web-based interface (JWAC)
• Compound Authentication2
• Microsoft® NAP (IPv4 / v6)
  - Support for 802.1x NAP
  - Support for DHCP NAP
• Guest VLAN
• RADIUS (IPv4 / v6)
• TACACS
• TACACS +
• XTACACS +
• Trusted Host
• RADIUS Accounting
• TACACS + Accounting
• Accounts with 4 levels of access rights
OAM
• Diagnosis cable
• 802.3ah Ethernet Link OAM
• 802.3ah D-link Unidirectional Link Detection (DULD)
• Y.1731 OAM2
• sFlow
Green Technology
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Reduced energy consumption:
  - Based on the connection status
  - Depending on the cable length
• Turn off the indicators
• Turning off the power ports
• A port in the standby mode
• Hibernate
Management
• Web-interface (Support IPv4 / v6)
• Command Line Interface (CLI)
• Telnet-server / client (Supports IPv4 / v6)
• TFTP-client (Supports IPv4 / v6) 2
• FTP-client (Supports IPv4 / v6)?
• ZModem
• Record of commands in the log (Command Logging)
• SNMP v1 / v2c / v3
• SNMP Traps
• System Log
• SMTP
• RMON v1:
  - Support groups 1,2,3,9
• RMON v2:
  - Support group ProbeConfig
• 802.1AB LLDP
• LLDP-MED
• BootP / DHCP-Client
• Auto Configuration via DHCP
• DHCP Relay (Supports IPv4)
• DHCP Relay Option 60, 61 and 82
• DHCP Client Option 12
• Add a label PPPoE Circuit-ID
• Support for multiple versions of software
• Flash File System
• CPU Monitoring
• View memory usage
• NTP / SNTP
• Use the debug (Debug Command)
• Restoration of the password
• Password Encryption
• Ping (Supports IPv4 / v6)
• Traceroute
• Microsoft® NLB (Network Load Balancing)
MIB
• RFC1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC1213 MIB II
• RFC1493, 4188 Bridge MIB
• RFC1157, 2571-2576 SNMP MIB
• RFC1901-1908, 3418, 3636, 1442, 2578 SNMPv2 MIB
• RFC271,1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665, 3635 Ether-like MIB
• RFC2668 802.3 MAU MIB
• RFC2674, 4363 802.1p MIB
• RFC2233, 2863 Interface Group MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC3298 MIB for Diffserv
• RFC 2925 Ping and Traceroute MIB
• Redundant configuration
• Ability to work via TFTP
• Trap MIB
• RFC 2465 IPv6 MIB
• RFC 2466 ICMPv6 MIB
• RFC 2737 Entity MIB
• Private MIB
• RFC 3289 DIFFSERV MIB
Standards IETF®
• RFC768 UDP
• RFC791 IP
• RFC792 ICMPv4
• RFC2463, 4443 ICMPv6
• RFC4884 Extended ICMP to Support Multi-Part Messages
• RFC793 TCP
• RFC826 ARP
• RFC1338, 1519 CIDR
• RFC2474, 3168, 3260 Definition of the DS Field in the IPv4 and IPv6 Header
• RFC1321, 2284, 2865, 2716, 1759, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
IPv6
• RFC2460 IPv6
• RFC2461, 4861 Neighbor Discovery
• RFC2462, 4862 IPv6 Stateless Address Auto-configuration
• RFC2464 IPv6 Neighbor over Ethernet and definition
• RFC3513, 4291 IPv6 Addressing Architecture
• RFC2893, 4213 IPv4 / IPv6 dual stack function
• IPv6 Ready Logo Phase 2
תקנים
הורדות
איורים
DGS-3000-24TC/DC
מראה מקדימה
מראה מאחורה
DGS-3000-24TC/A1
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
