חיפוש מהיר
תכונות המוצר:
מתג מנוהל WEB עם 8 פורטים במהירות ג'יגהביט, שתי יציאות ג'יגהביט/אופטי (SFP)
מאפיינים כללים:
Interfaces
• 8-port 10/100/1000 Mbit/s
• 2 SFP-port
Indicators
• Link / Activity / Speed ​​(per port 10/100/1000 Mbit / s)
Standards and Protocols
• IEEE 802.3 10BASE-T Ethernet (copper twisted pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (copper twisted pair)
• Compliance with IEEE 802.3az
• Auto-negotiation
• IEEE 802.3x Flow Control
Full / half duplex
• Full / half duplex for 10/100 Mbit / s
• Full duplex for Gigabit speed
Network Cables
• UTP Category 5, 5e (max. 100 m)
Determination of MDI / MDIX
• Automatic detection of MDI / MDIX on all ports on twisted pair
Switching matrix
• 20 Gb / s
Transmission Method
• Store-and-forward
Table MAC-addresses
• 16 000 entries per device
Update MAC-addresses
• Up to 256 static entries MAC-addresses
Speed ​​forwarding 64-byte packets
• 14,88 Mpps
Packet buffer
• 1,5 MB
Amount of RAM
• 128 MB
Flash-memory
• 16 MB
Layer 2 functions
• MAC-address table: 16K entries
• IGMP Snooping
• IGMP v1 / v2 Snooping
• Supports up to 256 IGMP-groups
• Support for up to 64 static multicast groups
• IGMP on VLAN
• Supports IGMP Snooping Querier
• Loopback Detection is
• 802.3ad Link Aggregation:
• Max. 5 groups per device / 8 ports per group
• LLDP
• LLDP-MED
• Jumbo-frame
• Up to 9216 bytes
• Spanning Tree Protocol
• 802.1D STP
• 802.1w RSTP
• Flow Control
• 802.3x
• HOL Blocking Prevention
• Port Mirroring
• One-to-One
• Many-to-One
• Supports mirroring for incoming / outgoing / traffic in both directions
• Multicast Filtering
• Redirect all unregistered groups
• Filtering of unregistered groups
• Customizable interface MDI / MDIX
• MLD snooping v1 / v2 (256 groups)
VLAN
• 802.1Q
• VLAN Group
• Max. 256 static VLAN-group
• Custom VID: 1 - 4094
• Asymmetric VLAN
• Auto Voice VLAN
• Max. the number of user-defined OUI: 10
• Max. OUI number Default: 8
• Auto Surveillance VLAN
Quality of Service (QoS)
• 802.1p
• 8 queues per port
• Mechanisms queuing
• Strict
• Weighted Round Robin (WRR)
• Bandwidth Management
• Based on the port (incoming / outgoing, with a minimum of 64 kbit / s for 10/100/1000)
• QoS based on:
• 802.1p Priority Queues
• DSCP
• ToS
• IPv6-Class Traffic
• Non-TCP / UDP-port
Function level 3
• IP-interface
• Supports 1 interface
Access Control Lists (ACL)
• Max. the number of access lists: 50
• Max. the number of rules for IPv4, MAC and IPv6: 768
• Each rule can be bound to the same port
• ACL based on:
• VLAN
• MAC-address
• Ether type
• IP-address
• DSCP
• the type of protocol
Security
• Protection from the broadcast / multicast / unicast storm
• D-Link Safeguard Engine
• DHCP Server Screening
• Binding IP-MAC-Port (Intelligent bindings)
• Supports 512 entries bindings
• Inspection ARP-packets
• Inspection ARP-packet + IP-packets
• Support for DHCP Snooping
• Access Control 802.1X port-based
• Prevention of ARP Spoofing Attacks
• Max. number of records: 64
• Segmentation of traffic
• SSH v2
• SSL
• Supports v1 / v2 / v3
• Port Security
• Supports up to 64 MAC-addresses per port
• Detection of the problems associated with the coincidence of network addresses
AAA
• Authentication 802.1X:
• Support local database / RADIUS-server
• Supports access control based on port
• Support for EAP, OTP, TLS, TTLS, PEAP
• RADIUS-server with support for IPv6
• Support for MD5 authentication
Standards MIB / RFC
• RFC 783 TFTP
• RFC 951 BootP / DHCP Client
• RFC 1157 SNMP v1, v2, v3
• RFC 1213 MIB II
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1769 SNTP
• RFC 1542 BootP / DHCP Client
• RFC 1901 SNMP v1, v2, v3
• RFC 1907 SNMP v2 MIB
• RFC 1908 SNMP v1, v2, v3
• RFC 2131 BootP / DHCP Client
• RFC 2138 RADIUS Authentication
• RFC 2139 RADIUS Authentication
• RFC 2233 Interface Group MIB
• RFC-2246 SSL
• RFC 2475
• RFC 2570 SNMP v1, v2, v3
• RFC 2575 SNMP v1, v2, v3
• RFC 2598 CoS
• RFC 2618 RADIUS Authentication
• RFC 2819 RMON v1
• RFC 2865 RADIUS Authentication
• RFC 3164 System Log
• RFC 3195 System Log
• RFC 3411-17 SNMP
• D-Link Private MIB
• LLDP MIB
• Zone Defense MIB
• 2233 Interface Group MIB
OAM
• Diagnosis cable
• Restore the factory default settings
Management
• Web-interface
• Utility D-Link Network Assistant
• Command Line Interface (CLI)
• Telnet-server
• TFTP-client
• Configurable MDI / MDIX
• SNMP
• Supports v1 / v2c / v3
• SNMP Trap
• Backup / software update
• Smart Wizard
• Download / upload the configuration file
• System Log
• Max. number of log entries: 500
• BootP / DHCP-client
• SNTP
• ICMP v6
• Support protocol stack IPv4 / v6
• Automatic configuration via DHCP
• Setting the time
• SNTP
• RMONv1
• Trusted host
Technology Green V3.0
• Energy savings based on:
• Determine the status of the connection
• PoE on schedule
• turn off the indicator
• Hibernation
• Turning off the port
IPv6
• RFC2460 IPv6
• RFC2461, 4861 Neighbor Discovery
• RFC2462, 4862 IPv6 Stateless Address Auto-configuration
• RFC2464 IPv6 Neighbor over Ethernet and definition
• RFC3513, 4291 IPv6 Addressing Architecture
• RFC2893, 4213 IPv4 / IPv6 dual stack function
נתונים פיזיים
Dimensions
• 280 x 126 x 44 mm
Weight
• 1,54 kg
Input supply
• 100-240 VAC, 50-60 Hz, internal universal power supply
Max. power consumption
• 13,59 W
Power consumption in standby mode
• 9,3 W / 100 V
• 9,4 W / 240
Heat dissipation
• 46,37 BTU / hr
MTBF (clock)
• 360,844
Noise level
• 0 dB
Temperature
• Operating: -5 to 50 ° C
• Storage: -20 to 70 ° C
Humidity
• Operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
Certifications
• CE Class A
• VCCI Class A
• FCC Class A
• cUL
• CE (LVD)
• BSMI
• CCC
• C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
