חיפוש מהיר
תכונות המוצר:
מתג מנוהל WEB עם 16 פורטים במהירות ג'יגהביט ושתי יציאות ג'יגהביט/אופטי (SFP)
מאפיינים כללים:
Hardware Version
• B1
Size
• 11-inch Desktop/Rackmount Size, 1U Height
Number of Ports
• 16 10/100/1000 Mbps
• 2 SFP 1000 Mbps
Port Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• IEEE 802.3ab compliance
• IEEE 802.3az compliant
• Auto-negotiation
• Auto MDI/MDIX
• IEEE 802.3x Flow Control supports Full-Duplex mode
• Supports half/full-duplex operation (full/half at 10/100 Mbps, full at 1000 Mbps)
Switching Capacity
• 36 Gbps
Maximum Forwarding Rate
• 26.79 Mpps
MAC Address Table Size
• 16K Entries
Packet Buffer
• 1.5 Mbits
Flash Memory
• 8 Mbytes
Power Consumption
Standby Mode
• 10.83 watts
Maximum Power Consumption
• 14.88 watts
VLAN
• Port-based VLAN
• 802.1Q Tagged VLAN
• Auto Surveillance VLAN
• Voice VLAN
• Management VLAN
• Asymmetric VLAN
• VLAN Group
  • Supports 128 static VLAN groups
  • Max. 4094 VIDs
L2 Features
• Flow Control
  • 802.3x Flow Control
  • HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• IGMP Snooping
  • IGMP v1/v2/v3 awareness Snooping
  • Supports 64 Groups
  • IGMP Snooping Querier
• 802.3ad Link Aggregation:
  • Support max 9 groups per device and 8 ports per group
• Loopback Detection
• Cable Diagnostics
• LLDP
• Port Mirroring
  • One-to-One
  • Many-to-One
• Statistics
  • Tx Ok
  • Tx Error
  • Rx Ok
  • Rx Error
• Spanning Tree Protocol
  • 802.1D STP
  • 802.1w RSTP
Quality of Service (QoS)
• 802.1p Quality of Service
• 4 queues per port
• Queue Handling
  • Strict
  • Weighted Round Robin (WRR)
• Port-based Bandwidth Control (Rate Limiting)
  • Ingress: 8Kbps, Egress: 64Kbps
Security
• D-Link Safeguard
• Traffic Segmentation
• Broadcast/Multicast/Unknown Unicast Storm Control
• DoS Attack Prevention
• SSL
Management
• Web-based GUI (Supports IPv4/IPv6)
• Client-based Utility (D-Link Network Assistant Utility)
Green Technology
• Power Saving by
  • Link Status
  • LED Shut-Off
  • Port Shut-Off
  • System Hibernation
• Compliant with IEEE 802.3az Energy Efficient Ethernet
MIB/RFC Standards
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC2233 Interface Group MIB
• RFC2665 Ether-like MIB
• 802.1p MIB RFC4363
• ZoneDefense MIB
• Private MIB
• RFC 951 BootP Client
• RFC 1542 BootP/DHCP client
• RFC 4363 802.1p
• RFC 2236 IGMP Snooping
נתונים פיזיים
Power Input
• 100 to 240 V AC
• 50 to 60 Hz Internal Power Supply
MTBF
• 2,671,256 hours
Acoustics
• 0 dB (A)
Heat Dissipation
• 50.77 BTU/hr
Weight
• 1.56 kg (3.44 lbs)
Dimensions
• 280 x 180 x 44 mm (11.02 x 7.08 x 1.73 inches)
Ventilation
• Fanless
Operating Temperature
• -5 to 50 °C (23 to 122 °F)
Storage Temperature
• -40 to 70 °C (-40 to 158 °F)
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
EMI
• FCC Class A, CE Class A, VCCI Class A, C-Tick, BSMI, CCC
Safety
• cUL, CE LVD, CB, BSMI, CCC
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
