DEM-435XTEOL EOS
תאור
DEM-435XT is 10GBASE-LRM SFP+ transceiver. 10GBASE SFP+ (Small Form-Factor Pluggable Plus) transceiver, which is targeted to support speed of 10Gbps, is an innovaitive, next-generation of 10GBASE transceiver. Compared with existing 10G XFP, 10G SFP+ is with smaller form factor, lower cost, lower power dissipation, and allows higher port density. The D-Link 10GBASE SFP+ transceivers offer customers a wide variety of 10Gbps Ethernet connectivity option for data center, enterprise wiring closet, and service provider transport applications.
מאפיינים כללים
Functions
• Hot Plug
• MSA Compliant
• RoHS Compliant
Standards
• IEEE-802.3aq
• 10GBASE-LRM
Transceiver type
• SFP +
Rate
• 10 Gb / s
Jack
• Duplex LC
Wavelength
• 1310
Optical output power (TX)
• Max: +0.5 dBm
• Min.: -8.5 DBm
Optical input power (RX)
• Max.: +0.5 DBm
• Min.: -6.5 DBm
Sensitivity
• -6.5 dBm
Type of cable
• Multimode fiber optic cable 50/125 or 62.5/125
