חיפוש מהיר
תכונות המוצר:
בקר אלחוטי משולב לניהול עד 256 נקודות גישה אלחוטיות בתקן N, עד 64 לכל בקר, כולל אבטחה מקיפה, פורטל ארגוני למשתמשים ואורחים וניטור הרשת האלחוטית
מאפיינים כללים:
WLAN control functions
• Up to 64 access points connected to the switch
• Up to 256 access points in a cluster
• Up to 2048 wireless clients (1024 users when using tunneling, 2048 users, if tunneling is not used)
Roaming
• Fast Roaming
• Roaming between switches and access points connected to one switch
• Intra - and Inter-network roaming
• Tunneling between access points
Access control and bandwidth
• Up to 32 SSID per access point (16 SSID to the radio frequency range)
• Load balancing between access points based on number of users or access point
Controlled access points
• DWL-8600AP
Management of access points
• Automatic detection of access points
• Remote reboot access points
• Monitoring of access points: the list of managed access points, unauthorized and unauthenticated access points
• Monitoring clients: a list of clients associated with each managed access point
• Monitoring customers Ad-hoc
• Authentication of access points using a local database or an external RADIUS server
• Centralized management channels / security policies
• Visual management tools access points (Up to 16 jpg-files)
• Support for a unified access point (DWL-8600AP): Managed / Offline
Functions of WLAN Security
• Wireless Intrusion Detection & Prevention System (WIDS)
• Minimize unauthorized access points
• Classification of real and unauthorized access points based on MAC addresses
• WPA Personal / Enterprise
• WPA2 Personal / Enterprise
• 64/128/152-bit WEP-encryption
• Classification of wireless stations and access points based on the channel, MAC-addresses, SSID, time
• Support for encryption types:
  -WEP
  -WPA
  -Dynamic WEP
  -TKIP
  -AES-CCMP
  -EAP-FAST
  -EAP-TLS
  -EAP-TTLS
  -EAP-MD5
  -PEAP-GTC
  -PEAP-MS-CHAPv2
  -PEAP-TLS
• Adaptive portal
• Authentication based on MAC addresses
• Insulation Station
Layer 2 features
• Size MAC-address table: 8K entries
• IGMP Snooping: 1K multicast groups
• MLD Snooping
• 8021.D Spanning Tree
• 802.1w Rapid Spanning Tree
• 802.1s Multiple Spanning Tree
• Link Aggregation 802.3ad: up to 32 groups, up to 8 ports per
• 802.1ab LLDP
• LLDP-MED
• One-to-One Port Mirroring
• Many-to-One Port Mirroring
• Size Jumbo-frames: up to 9Kb
VLAN
• 802.1Q VLAN Tagging
• 802.1V
• Group VLAN: up to 3965 entries
• VLAN-based subnetworks
• VLAN MAC-based address
• GVRP
• Double VLAN
• Voice VLAN
Level 3 functions
• Static IPv4 marshrutizatizatsiya
• Routing table size: up to 128 static routes
• Floating static routes
• VRRP
• Proxy ARP
• RIPv1/v2
Quality of Service (QoS)
• Priority queue 802.1p (8 queues per port)
• CoS on the basis of: a switch port, VLAN, DSCP, port TCP / UDP, TOS, MAC-source address, IP-address of the source
• Auto-VoIP
• The minimum guarantee bandwidth for all
• Traffic shaping per port
• Bandwidth management based on the flow
ACL (Access Control List)
• ACL based on:
  - Switch port
  - MAC-address
  - Priority queues 802.1p
  - VLAN
  - Ethertype
  - DSCP
  - IP-address
  - Protocol type
  - Port
  - TCP / UDP
LAN security functions
• RADIUS authentication for administrative access
• TACACS+ authentication for administrative access
• SSH v1, v2
• SSL v3, TLS v1
• Function Port Security: MAC-20 addresses per port, a notice in case of a function
• MAC-address filtering
• Access control 802.1x port-based and Guest VLAN
• Protection against DoS attacks
• Dynamic ARP Inspection (DAI)
• DHCP Snooping
• Broadcast Storm Control: step 1% of the speed channel
• Protected Port
• DHCP-filtering
Management methods
• Web-interface
• Switch Clustering
• Account RADIUS
• CLI
• Server Telnet: up to 5 sessions
• Telnet Client
• TFTP client
• SNMP v1, v2c, v3
• SFlow
• Multiple configuration files
• Support for two copies of the Software (Dual Images)
• RMON v1: 4 Groups (Statistics (Stats), History (History), Alarms (Notices), Events (Event))
• Client BOOTP / DHCP
• DHCP server
• DHCP Relay
• SYSLOG
• Port Description
Device Interfaces
• 24 10/100/1000BASE-T ports with support for PoE 802.3af
• 4 combo SFP ports
• Console RS-232 port
• 2 open slots for additional modules with 10 Gigabit
Reserve power supply
• Connector for power supply DPS-600
Power over Ethernet
• Standard: 802.3af
• Output power per port: 15.4W
• Total power output: 370 W
• Auto Port at a value of current above 350mA
Performance
• Switching matrix 88 Gb / s
• Max. packet rate: 65,47 Mpps
• Transmission Method: Store and Forward
• Buffer packets: 750 KB
Flow Control
• 802.3x Flow Control in full duplex mode
• The method of "back pressure" in half-duplex mode
• HOL Blocking Prevention
Additional uplink-port 10GE modules
• DEM-410X Module 1 slot 10GE XFP (For connection to a fiber backbone)
• DEM-410CX module 1-port 10GE CX4 (for stacking switches)
Additional transceivers XFP 10GE
• DEM-421XT transceiver XFP 10GBASE-SR, MMF, max. distance of 300 m, 3.3 / 5V
• DEM-422XT transceiver XFP 10GBASE-LR, SMF, max. distance to 10 km, 3.3 / 5V
• DEM-423XT transceiver XFP 10GBASE-ER, SMF, max. distance of 40 km, 3.3 / 5V
Diagnostic Lights
• On the device: Power, Console, RPS
• For the port 10/100/1000BASE-T: Link / Activity / Speed, PoE
• For Slot SFP: Link / Activity
• For the slot 10 Gigabit: Link / Activity
נתונים פיזיים
Power
• Power Supply: Internal universal power supply from 100 to 240 VAC, 50/60 Hz
• Power: 525 watts (max. with the operation of all ports PoE)
MTBF
• 185.540 hours
Dimensions
• 440 (W) x 389 (D) x 44 (H) mm
• Set 19 "rack, 1U
Weight
• 6kg
Temperature
• Operating Temperature: 0 ° to 40 ° C
• Storage Temperature: -10 ° to 70 ° C
Humidity
• Operating Humidity: 10% to 90% without condensation
• Storage Humidity: 5% to 90% without condensation
Electromagnetic compatibility
• FCC Class A, ICES-003, VCCI, CE, C-Tick, EN 60601-1-2
Security
• UL / cUL, CB
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
