Description
D-Link®, provider of Firewall/VPN Security Appliances, introduces the VPN Client software to complement the NetDefend family of firewall hardware. This VPN client software provides a complete and secure way for remote clients to communicate with their company headquarters. With growing concerns over network security, Denial of Service attacks, virus damage, and privacy demands, D-Link’s NetDefend family of network security solutions offer the reliability and protection that businesses need.
IPSec Client Solution
The
D-Link VPN Client Software is an easy-to-use, secure and economical
IPSec client. Designed for IPSec Virtual Private Network (VPN)
products, each computer running this VPN client can instantly connect
to D-Link IPSec-enabled gateways, such as D-Link VPN routers and
NetDefend firewalls over a wired or wireless network, the Internet or a
private network.
In addition, D-Link’s VPN client is VPNC (VPN Consortium) Certified to ensure compatibility with other approved manufacturers’ firewall hardware. When a connection is established between the VPN firewall and the VPN client, all data traversing the network is protected by the latest encryption algorithms to ensure maximum security.
Data Encryption & User Authentication
The
D-Link VPN Client uses standards-based IPSec with advanced 3DES/AES
encryption and Windows® support. This software provides the capability
to work with most RADIUS authentication methods and also supports
centralized database management.
Intuitive Security Solution and Management
With
the D-Link VPN Client, your mobile users have a simple and
straightforward solution for securely accessing the corporate network.
The D-Link VPN Client software provides mobile users with secure,
reliable access to sensitive resources through broadband, wireless, or
dial-up connections. Roadwarriors and telecommuters can easily
communicate via hotspots on the road or via their home connection using
IPSec NAT-Traversal.
Hardware Support
The D-Link VPN Client software provides connections for mobile users with all NetDefend VPN/Firewalls including the DFL-200, DFL-700, DFL-800, and DFL-1100.
