DFL-1100EOL EOS
Network Security Firewall for Enterprise
Description
Multi-Function Security Application
The DFL-1100 features enterprise-grade firewall functions, including Stateful Packet Inspection (SPI), detect/drop intruding packets, embedded VPN, a physical DMZ port, multiple-mapped IPs and multiple virtual servers. The DFL-1100 connects your office to a broadband modem such as cable or DSL through an external 10/100BASE-TX WAN port.
Full Firewall Functions
The DFL-1100 provides complete firewall functions, including the NAT mode, PA T (Port Address Translation) mode, Routing mode and SPI. It also supports customized policy and virtual server configuration. Administrators can easily manage the network through graphical statistics in a logging/monitoring system.
High Performance IPSec VPN Support
The DFL-1100 is equipped with embedded VPN support, allowing you to create multiple IPSec tunnels to remote sites/clients. IPSec on the DFL-1100 uses strong encryption with DES, 3DES, AES and Automated Key Management via IKE/ISAKMP . A VPN tunnel can be activated from the DFL-1100 to a remote site or a mobile user for secured traffic flow using triple DES encryption. This offers users a way to confidentially access and transfer sensitive information. Multiple VPN tunnels may be easily created without the need to setup IKE (Internet Key Exchange) policies.
Access Control List (ACL)
URL blocking is part of basic features offered by DFL-1100. This function provides the benefit of limiting access to undesirable Internet sites. Logs of real-time Internet traffic, alarms of Internet attacks, and notice of web-browsing activities are logged and can be reported through e-mail notification. DFL-1100 supports Radius authentication so you can make use of your existing Radius Server and user information.
Advanced Features for Complete Protection
DFL-1100 provides advanced features including Content filtering, IDS (Intrusion Detection System), Bandwidth Management for complete solution protection to users's network. Content Filtering lets you filter/protect your network with customized policy. Bandwidth management guarantees bandwidth for different services.
The DFL-1100 protects your network from attacks. It can be configured to log all attacks, locate the source IP address generating the attack, send the attack report notification to a specified e-mail address and establish policies to restrict incoming traffic from specific IP address sources. Network administrators can set e-mail addresses to receive alert message from the DFL-1100. When intrusion events are detected, the DFL-1100 will log them and send alert e-mail, and the administrator can check the log file on the router to find out what happened.
High Performance With Fault Tolerance
The DFL-1100 can operate with up to 200,000 concurrent sessions, providing up to 1,000 VPN tunnels for up to 1,000 mobile telecommuters needing secure remote connections to the company network. In addition, this firewall also provides fault tolerance through redundancy backup with another firewall through a backup port, providing continuous firewall protection for mission-critical applications.
1 DMZ Port, 1 Trusted LAN Port, 1 Backup Port
The DFL-1100 includes a LAN port that connects to your internal office network, a backup port that connects to another firewall, and a physical DMZ (Demilitarized Zone) port that can connect your Web,
mail or FTP servers for access from the Internet. DMZ alleviates congested server traffic from entering the Internal network, while protecting your other office computers from Internet attacks by hiding them behind the firewall.
General features
Certificates
Order info
Pictures
DFL-1100
Front view
Downloads
Support Resources
