DAP-1320EOL EOS
Wireless Range Extender N300
Description
The DAP-1320 Wireless Range Extender N300 is a portable plug-in repeater that lets you extend an existing wireless network. You can place it anywhere in your home to increase the range of your wireless network. Tiny yet powerful, it supports Wireless N speeds of up to 300 Mbps in a
device that fits in the palm of your hand.
Easy to set up, easy to use
Setting up the Wireless Range Extender N300 is simple to do with several convenient ways. You can use the supported QRS Mobile app on your iOS or Android mobile device to set up the DAP-1320 easily without needing to be at a computer. Alternatively, you can use One-touch configuration by pushing the WPS push-button on the DAP-1320 and on the router or AP you want to extend. You can also simply plug the DAP-1320 in, connect to it wirelessly with a PC or mobile device, and follow the steps in the built-in Setup Wizard to configure the DAP-1320.
Compact, convenient design
The DAP-1320‘s compact design is ideal for use at home or a small office, as it does not take up much space and is ready to use by simply plugging it in. The repeater’s small form means it can easily be plugged into a power outlet without blocking other outlets while its wall wart design saves you the hassle of dealing with a power cord. Its sleek, unobtrusive appearance means it blends easily into the background.
General features
Device interfaces
• 802.11n/g/b
• WPS button
• Reset button
LEDs
• Status/WPS
Standards
• IEEE 802.11b/g/n
Wireless speed
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit/s
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit/s
• IEEE 802.11n*:
  MCS GI=800ns GI=400ns
20MHz 40MHz 20MHz 40MHz
  0 6,5 13,5 7,2 15
  1 13 27 14,4 30
  2 19,5 40,5 21,7 45
  3 26 54 28,9 60
  4 39 81 43,3 90
  5 52 108 57,8 120
  6 58,5 121,5 65,0 135
  7 65 135 72,2 150
  8 13 27 14,444 30
  9 26 54 28,889 60
  10 39 81 43,333 90
  11 52 108 57,778 120
  12 78 162 86,667 180
  13 104 216 115,556 240
  14 117 243 130 170
  15 130 270 144,444 300
The output power of the transmitter
• IEEE 802.11b:
  20 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  20 dBm at 6-36 Mbit/s
  19 dBm at 48 Mbit/s
  18 dBm at 54 Mbit/s
• IEEE 802.11n:
  HT20
  20 dBm at MCS0-MCS4 and MCS8-MCS12
  19 dBm at MCS5 and MCS13
  18 dBm at MCS6-MCS7 and MCS14-MCS15
  HT40
  19 dBm at MCS0-MCS5 and MCS8-MCS13
  18 dBm at MCS6 and MCS14
  17 dBm at MCS7 and MCS15
Receiver sensitivity
• IEEE 802.11b:
  -87 dBm at 1 Mbit/s
  -87 dBm at 2 Mbit/s
  -85 dBm at 5.5 Mbit/s
  -82 dBm at 11 Mbit/s
• IEEE 802.11g:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbits/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -74 dBm at 24 Mbit/s
  -70 dBm at 36 Mbit/s
  -66 dBm at 48 Mbit/s
  -65 dBm at 54 Mbit/s
• IEEE 802.11n:
  20MHz
  -82 dBm at MCS-0/8
  -79 dBm at MCS-9/1
  -77 dBm at MCS-2/10
  -74 dBm at MCS-3/11
  -70 dBm at MCS-4/12
  -66 dBm at MCS-5/13
  -65 dBm at MCS-6/14
  -64 dBm at MCS-7/15
  40MHz
  -79 dBm at MCS-0/8
  -76 dBm at MCS-9/1
  -74 dBm at MCS-2/10
  -74 dBm at MCS-3/11
  -67 dBm at MCS-4/12
  -63 dBm at MCS-5/13
  -62 dBm at MCS-6/14
  -61 dBm at MCS-7/15
Frequency range
• From 2.4GHz to 2.4835GHz
Antennas
• Two internal antennas
Plug type
• Region dependent
Security
• Wi-Fi Protected Access (WPA and WPA2)
• 64/128-bit WEP encryption
• WPS (PBC)
Advanced Features
• QR app support (iOS, Android)
Device management
• Web UI
Certificates
Order info
Pictures
DAP-1320/Ax
Front view
Left side view
Back view
Downloads
Support Resources
