DHP-301EOL EOS
Description
USE EXISTING WIRING TO CREATE A HOME NETWORK
D-Link's PowerLine HD Ethernet Starter Kit (DHP-301) is an ideal solution for connecting computers, HD media players, game consoles, and network attached storage to your home network. By simply attaching one adapter from your router into your existing electrical system*, you can turn every power outlet into a possible network connection.
EXPAND YOUR NETWORK WITHOUT RUNNING WIRES
D-Link's PowerLine HD Ethernet technology extends your network's range without drilling holes into walls by utilizing your home's existing electrical system. This device is also ideal for homes or small offices where concrete walls, successive floors in multi-storied buildings, or other architectural impediments could inhibit a wireless signal. Connect multiple devices in the farthest corners of your home by attaching a switch or wireless access point to a D-Link PowerLine HD Ethernet Adapter*.
CONVENIENTLY CONNECT
D-Link's PowerLine HD Ethernet Adapter transmits data reliably by intelligently adapting to the strongest signal channels. In addition to a maximum throughput rate of 200Mbps**, D-Link's PowerLine HD Ethernet Adapters include a built-in Quality-of-Service (QoS) engine that prioritizes data packets in order to enhance HD video and audio streaming, intense online gaming, and VoIP calling. Plus, D-Link's Powerline HD Ethernet Adapters implement 3DES encryption for securing your connection to help keep your data safe from intruders.
With hassle-free plug & play installation, D-Link's PowerLine HD Ethernet Starter Kit (DHP-301) is an ideal solution to create a wall-to-wall home network.
WHAT THIS PRODUCT DOES
D-Link's PowerLine HD Ethernet Starter Kit (DHP-301) takes advantage of your home's existing electrical wiring* to create or extend a network. Turn every power outlet into a possible network connection to connect computers, digital media players, and game consoles throughout your house.
