DKVM-IP8EOL
8/16 Port IP Combo KVM (USB Local Console)
Description
	DKVM-IP8 defines a new class of remote KVM access device; it combines digital remote KVM access via IP networks with comprehensive and integrated system management.
	DKVM-IP8 owes a convenient, remote KVM access and control via LAN or Internet. It captures, digitizes, and compresses video and transmits it with keyboard and mouse signals to and from a remote computer. Also it provides a non-intrusive solution for remote access and control. Remote access and control software runs on its embedded processors only but not on mission-critical servers, so that there is no interference with server operation or impact on network performance.
General features
				 PC Connection
				 Direct
				 8
				 Max. via Daisy Chain
				 120 (8 port + 16 port * 7 levels)
				 Port Selection
				 Push button, Hotkey, OSD
				 Connectors
				 Console
				 Keyboard
				 1*Mini Din 6 Female (Purple)
				 Video
				 1*HDB15 Female (Blue)
				 Mouse
				 1*Mini Din 6 Female (Green)
				 Computer
				 8*SPHD 15 pin Female (Blue)
				 Daisy Chain
				 Keyboard
				 Video
				 Mouse
				 Serial Port
				 1*DB9 pin Male
				 USB Port
				 1*USB 2.0 Type B
				 LAN
				 1*RJ-45 Female
				 Power
				 1*DC Jack (Black)
				 Emulation
				 Keyboard / Mouse
				 PS/2
				 LED
				 Online
				 8
				 10 / 100 Mbps
				 1 (Orange / Green)
				 7-Segment
				 1
				 Scan Intervals
				 5~99 Sec
				 Reset button
				 1
				 VGA Resolution
				 • l Local: 1600*1200
				• l Remote: 1280*1024
				 Environment
				 Operation Temperature
				 0 ~ 5°C
				 Storage Temperature
				 -20 ~ 60°C
				 Humidity
				 0 ~ 80%, Non-Condensing
				 Power Adapter
				 DC 5V, 2.5A
				 Physical Properties
				 Housing
				 Metal
				 Weight
				 2,600g
				 Dimensions (L*W*H), mm
				 44*430*220
Certificates
Order info
DKVM-IP8  8/16 Port IP Combo KVM (USB Local Console)
