DKVM-IPVUCB
KVM cable for monitor, keyboard and mouse connection
Where to buy
Description
1.8 m KVM Cable DKVM-IPVUCB is designed to connect a monitor, keyboard and mouse and it is compatible with KVM over IP DKVM-IP8 switch. DKVM-IPVUCB is a set of "two in one" cables, which includes a VGA cable (with 15-pin HDD male connectors) for VGA monitor connection, and a USB 2.0 cable for connection between computer and KVM switch.
DKVM-IPVUCB is a "all in one" cable. It saves space on a desktop, as it integrates several cables into one. Each cable has a color code (PC99), providing proper connection.
General features
General
• "All in one" cable
• Color code
Keyboard and mouse
• USB 2.0 connector (black)
Monitor
• 15-pin VGA male connector (blue - from the PC's side)
Single connector for monitor, keyboard and mouse connection to KVM over IP switch
• 15-pin SPHD connector (yellow - from the KVM over IP switch's side)
Physical parameters
Operating supply voltage
• 300 V
Cable length
• 1.8 m
Weight:
• 148 g
Certificates
Order info
DKVM-IPVUCB  KVM cable for monitor, keyboard and mouse connection
Pictures
DKVM-IPVUCB
Downloads
Support Resources
