KVM-440EOL EOS
PS2/USB 8 Port Combo KVM Switch
Description
Versatile Management
Toggle between clients using the front panel buttons, keyboard hotkeys, or On-screen Display (OSD) menu. The on-screen menu allows you to label each channel with a descriptive name, providing clear and easy navigation. A convenient Auto-Scan function allows you to automatically toggle between multiple computers sequentially at preset intervals. The front panel LEDs assist with workstation/server status monitoring. Green LEDs indicate that systems are online, while separate red LEDs indicate when a particular system has been selected for management via console.
Convenient Installation
The sturdy metal chassis is mountable in a standard 19-inch rack. Daisy chain multiple KVM switches together up to three levels deep; cascaded units require no special configuration and automatically configure themselves as master or slave. Target workstations can be connected via keyboard/mouse or PS/2 using a custom combo cable. A PS/2 or USB keyboard is emulated on each terminal allowing all attached computers to successfully boot without keyboard errors. Hot-pluggable connections allow you to add devices to or remove them from the KVM switch without the need to shut it down.
Important!
Standard package contents include four 1.8 m cables.
KVM-401 (1.8 m), KVM-402 (3 m), KVM-403 (5 m) cables are optionally available.
General features
Features
Number of Computers Controlled
• 8
Selection Method
• Push Button and Hot-Key (PS/2 Keyboard) or On-Screen-Display (OSD)
LEDs
• Red for PC Selection
• Green for PC Online/Ready
PC Connectors
• Video: 8 x HDB-15 female
• Keyboard/Mouse: PS/2 & USB Signal Combined
Console Ports
• Keyboard: 1 x 6 pin mini-DIN female
• Mouse: 1 x 6 pin mini-DIN female
• Video: 1 x HDB-15 female
Firmware Upgrade Port
• Mini USB
Auto-Scan Interval
• Adjustable time setting by OSD menu
DDC, DDC2 monitor
• Maximum resolution up to 2048 x 1536 @ 65 Hz
Hot-swappable
• Yes
Operating Systems Supported
• Windows 98SE/ME/2000/2003/2008/XP/Vista/7, Linux, Mac OS 9/OS X, Sun Microsystems
Physical Parameters
Power
• By external power adapter
Dimensions (L x W x H)
• 44 x 15.7 x 4.5 cm
Weight
• 1750 g
Housing Material
• Metal
Operating Temperature
• 0 to 50В°C
Humidity
• 0% to 80% Relative Humidity
Certifications
• FCC, CE, C-Tick, IC, CSA
• Four 1.8 m cables
Certificates
Order info
KVM-440  PS2/USB 8 Port Combo KVM Switch
Pictures
KVM-440/Ax
Front view
Back view
Back view
Downloads
Support Resources
