Kirjeldus
Flexible Installation
The DP-G310 is ideal for both the large office and the small WEP (Wired Equivalent Privacy) encryption protocol. Data workgroup. For homes and SOHO with just one printer to privacy mechanism is based on a shared key algorithm, as share, this print server offers a single port and saves you the described in the wireless LAN standard.cost. For the large office with many computer users and several printers scattered at different places, you can plug one print server to each of these printers to share them on the network.
Ethernet and Wireless Interfaces
Two LAN interfaces are provided on this print server: (1) a 10/100BASE-TX Ethernet port and (2) a high-speed 802.11g wireless LAN interface supporting up to 54Mbps network data transfer. This flexibly allows both Ethernet users and wireless users to print files through the print server.
Wireless Network Security
The DP-G310 provides the necessary security for wireless users, using the user-selectable 64/128-bit industry-standard WEP (Wired Equivalent Privacy) encryption protocol. Data privacy mechanism is based on a shared key algorithm, as described in the wireless LAN standard.
Remote Printing Support
The DP-G310 supports IPP (Internet Printing Protocol), so you can set an IP address in the print server for remote users to output print files to the printers from remote places.
Setup & Access Control
Setting up the print server can be done from any workstation running a web browser. In addition, Windows-based menu-driven program allows you to do administration jobs and set access control. Access to your network printer can be control by setting up a list of MAC addresses of user computers allow to print files. SNMP and latest MIB-II MIBs are built into the print server, allowing you to manage
this device on an SNMP standard-based network
