DVG-5402SPEOL EOS
2-pordine VoIP ruuter
Kirjeldus
INTERNET PHONE MADE FOR HOME & SOHO
The D-Link DVG-5402SP VoIP Router allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network technology with advanced communication features, and is compatible with industry-wise phone service. This VoIP Router connects you to up to two ordinary phone sets to let you make phone calls. Router connects you to up to two ordinary phone sets to let you make phone calls.  connects you to up to two ordinary phone sets to let you make phone calls.
SUPERIOR VOICE QUALITY
The DVG-5402SP incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference, phone book, speed dialing and hot lines to make it convenient to dial out or answer phone calls.
COMPLETE SECURITY
The DVG-5402SP supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides a lifeline phone port to relay your incoming and outgoing phone calls to PSTN in case when a power down occurs. This guarantees that your phone connection will always be available.
INTEGRATED 4-PORT ROUTER
The DVG-5402SP provides a convenient router function to permit multiple computers to share an Internet broadband line. With four integrated Ethernet ports, four computers can connect to the DVG-5402SP and use its built-in NAT/DHCP server functions to log on to the Internet.
Põhiomadused
Liidesed
  • 2 FXS porti RJ-11
  • 1 FXO port RJ-11, lifeline funktsiooni toetus
  • 1 WAN 10/100Base-TX port RJ-45, MDI/MDIX
  • 4 LAN 10/100Base-TX porti, RJ-45, MDI/MDIX
    SIP funktsioonid
  • Individuaalne kasutajatunnus iga pordi jaoks või üldine kasutajatunnus kõikide portide jaoks
  • Helistaja ID tuvastamine (Caller ID)
  • Otsekõne IP-to-IP ilma SIP Proxy
  • Numeratsiooni plaan (Digit Map) ja telefoniraamat
  • DNS SRV, SIP SRV
  • Numbri valimine E.164 (ENUM)
  • Hot Line, Warm Line
  • Interaktiivse häälvastuse häälestamine (IVR)
  • Muusika mängimine kõne hoidmisel
  • Outbound Proxy
  • SIP INFO
  • Kolmesuunaline konverents (Ad Hoc režiim, meediaserver nõutud)
  • Kõne funktsioonid:
    • Anonüümsete kõnede blokeerimine
    • Kõnede blokeerimine ja filtreerimine helistaja IP-aadressi järgi
    • Kõne suunamine (kinni, ei vasta, tingimusteta)
    • Kõnede ajalugu (kõnede staatus)
    • Kõne hoidmine
    • Kõne suunamine fikseeritud numbrile (Call park), (Call Retrieve) (Proxy toetus)
    • Kõne suunamine (Proxy toetus)
    • Ootekõne
    • Helistaja nimi ja kõneaeg (FSK)
    • «Mitte tülitada» funktsioon (Do not disturb)
    • Blokeerimine Caller ID järgi
    Hääle funktsioonid
  • Reguleeritav jitter-buffer
  • Kajasummutus
  • Hääle/faksi/andmete automeetne tuvastmine ja ümberlülitamine
  • Auto Gain Control (AGC)
  • Kodekid: G.711μ/A-law, G.729A/B/AB, G.723 (6.3/5.3 Kbit/s), G.726
  • Komfortse müra genereerimine (CNG)
  • DTMF tuvastamine ja genereerimine
  • In-band või Out of band DTMF event
  • Packet Lost Concealment (PLC)
  • Hääle/faksi/modemi (kuni 33.6 Kbit/s) toetus IP peale
  • T.30 fax bypass thought G.711
  • T.38 real time FAX до 14.4 Kbit/s
  • Voice Activity Detection (VAD)
  • Helistaja ID (Caller ID) tuvastamine ja genereerimine: DTMF, FSK-BellCore, FSK-ETSI
    Häälestamine/Juhtimine
  • Automatic Provisioning (v.a. TR069/TR104)
  • Web-интерфейс управления пользователя
  • Kasutajaliides TELNET
  • Konfigureerimisfaili salvestamine ja taasatamine veebiliidese kaudu
  • Kõnede ajalugu (vastuvõetud, vastamata kõned, blokeeritud kõned)
  • Call Detail Record (CDR)
  • Aja sünkroniseerimine vastavalt NTP (vaikimisi NTP D-Link serveriga)
  • Kaitse parooliga (Web-liides ja TELNET)
  • Ping Test
  • Algseadete taastamine
  • SNMPv2 (v.a. TR069/TR104)
  • Staatilised marsruutid ja vaike marsruutid
  • System status
  • TFTP/FTP/HTTP-klient tarkvara uuendamiseks
  • TR069/TR104 kliendi toetus (valikuline)
    WAN-ühendus
  • Big Pond klient
  • DHCP-klient
  • PPPoE autentimine PAP/CHAP kaudu
  • PPTP-klient
  • Staatiline IP-aadress
    Качество обслуживания (QOS)
  • DiffServ (DSCP) или ToS IP Precedence tagging (WAN)
  • Ограничение скорости на порту LAN
  • Ограничение скорости на порту WAN (с шагом 64Кбит/с)
  • Очередь приоритетов WAN-порта: сначала RTP
  • 802.1Q и 802.1P Tagging (1 VID для VoIP-трафика, 1 VID для LAN-трафика)
    NAT TRAVERSAL
  • STUN-клиент
  • DDNS-клиент
  • Задание диапазона портов для SIP и RTP
  • Статический маршрут
  • Встроенный межсетевой экран
  • Фильтрация IP-адресов
  • Фильтрация на основе портов
  • Фильтрация на основе MAC-адресов
  • Виртуальный сервер
  • DMZ
  • Защита от атак Denial of Service (DoS)
  • Аутентификация MD5 для SIP
  • Два уровня привилегий: Administrator и User
  • VPN Pass-through with Multiple Sessions (IPSec, PPTP, L2TP)
  • Sertifikaadid
    Sidustooted
    Pildid
    DVG-5402SP/A1
    Eestvaade
    Tagantvaade
    Failid
    Vaadake samuti
