Kirjeldus
USB port
The router is equipped with USB port, allowing to connect a USB modem, which provides quick Internet access. In addition, you can connect USB drive to the USB port on the router, which will be used as a network drive or a printer.
ADSL port and 4-port switch, Ethernet WAN support
ADSL router provides port for connecting to ADSL line. Built-in 4-port switch allows you to connect computers equipped with Ethernet adapters, game consoles and other devices to your network. In addition, any Ethernet-enabled devices can be used to connect to a dedicated Ethernet line.
Security
DSL-2650U Wireless Router has a built-in firewall. Enhanced security functions minimize threats of hackers and prevent intrusions to your network and access to adverse websites for users on your local network.
Wireless interface
You can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network almost anywhere (within range of a wireless network). The router can serve as an access point to connect to the wireless network of 802.11b, 802.11g and 802.11n devices. The device supports several security standards (WEP, WPA/WPA2), provides MAC address filtering and allows you to use the WPS technology.
Configuration and management
You can configure and manage the settings of the DSL-2650U router via the user-friendly web-based interface (the interface is available in several
languages).
Põhiomadused
Hardware
Interfaces
• ADSL: one RJ-11 port
• LAN: four RJ-45 10/100BASE-TX Fast Ethernet ports with auto-MDI/MDIX
• WLAN: built-in 802.11b, g, n wireless interface
Data rate
• 802.11b: 11, 5.5, 2, 1 Mbit/s
• 802.11g: 54, 48, 36, 24, 18, 12, 9, 6 Mbit/s
• 802.11n
HT20: 150, 130, 117, 104, 78, 52, 39, 26, 13 Mbit/s
HT40: 150, 130, 117, 104, 78, 52, 39, 26, 13 Mbit/s
ADSL standards
• ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
• ADSL2+: ITU-T G.992.5 Annex A/L/M
Software
WAN connection types
• 3G
• ADSL
PPPoE
PPPoA
IPoA
Static IP
Dynamic IP
Bridge
• Ethernet
PPPoE
Static IP
Dynamic IP
Bridge
Wireless network
• IEEE 802.11n standard, IEEE 802.11b/g compliant
• Support of guest wireless network
• WEP encryption
• WPA/WPA2 security with TKIP, AES and TKIP+AES
• MAC-based access to wireless network
• PIN and PBC methods of WPS
• Advanced settings
ATM/PPP protocols
• Bridged and routed Ethernet encapsulation
• VC/LLC-based multiplexing
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVCs)
• ATM Adaptation Layer Type 5 (AAL5)
• ITU-T I.610 OAM F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2364)
• PPP over Ethernet (PPPoE)
• Keep-alive for PPP connections
Network protocols and features
• Additional IP address for LAN interface
• Static IP routing
• NAT (Network Address Translation)
• DHCP server/client/relay
• DNS relay
• Dynamic DNS (DDNS)
• VLAN support
• IGMP proxy
• IGMP snooping
• TR-069 Client
• RIP
• UPnP
• Reservation
Firewall and access management functions
• MAC filtering based on time of day and day of week
• URL filter
• Packet filtering (IP/ICMP/TCP/UDP)
• Virtual servers
• Prevention of DoS attacks
• Intrusion detection system and event logging
• DMZ
• Port Triggering
QoS
• Interface grouping
• VLAN priority (802.1p)
USB-modem*
• Automatically connects to available type of supported network (3G/2G)
• Enable/disable PIN verification, change PIN
USB drive
• Access via SMB
• File browser
• Print server
• Access to storage with accounts
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Firmware upgrade via Web-based interface
• Supports remote logging
• Ping
Supported USB modems**
• GSM modems
Huawei E171
ZTE MF192
ZTE MF626
ZTE MF652
• CDMA modems
Airplus MCD-650
Airplus MCD-800
ZTE AC5730
Sertifikaadid
Sidustooted
DSL-2650U/B1A/T1A Wireless N ADSL2+ Modem Router with USB Port
