DAP-2690EOL EOS
AirPremier N Simultaneous Dual Band PoE Access Point with Plenum-rated Chassis
Kirjeldus
The DAP-2690 AirPremier N Simultaneous Dual Band PoE Access Point with Plenum-rated Chassis is designed for supporting small and medium business environments or enterprise corporations by providing secure and manageable dual band wireless LAN options for network administrators.
Versatile Access Point
The DAP-2690 allows network administrators to deploy a highly manageable and extremely robust simultaneous dual band wireless network. All four antennas on the DAP-2690 are detachable and can provide optimal wireless coverage in either 2.4 GHz (802.11g and 802.11n) and 5 GHz (802.11a and 802.11n) bands. Enclosed in a plenum-rated metal chassis, the DAP-2690 adheres to strict fire codes for placement in air passageways.* For advanced installations, the DAP-2690 has integrated 802.3af Power over Ethernet (PoE) support, allowing this device to be installed in areas where power outlets are not readily available. The DAP-2690 is equipped with Atheros AR9344 (600 MHz) processor, DDR2 SDRAM 128 MB and SPI Flash 16 MB.
Enhanced Performance
The DAP-2690 delivers reliable, high-speed wireless performance with maximum wireless signal rates of up to 300 Mbps** in both the 2.4 GHz and 5 GHz wireless bands. This, coupled with support for the Wi-Fi MultimediaTM (WMM) Quality of Service feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-2690 to automatically prioritize network traffic according to the level of interactive streaming, such as gaming or VoIP. The QoS feature can be adjusted using the DAP-2690’s web GUI using a drop-down menu option to select customized priority rules. Additionally, the DAP-2690 supports load balancing to ensure maximum performance by limiting the maximum number of users per Access Point.
Security
To help maintain a secure wireless network, the DAP-2690 supports both Personal and Enterprise versions of WPA and WPA2 (802.11i) with support for RADIUS server backend and a built-in internal RADIUS server allowing users to create their accounts inside. This access point also includes MAC Address Filtering, Wireless LAN segmentation, Disable SSID Broadcast, Rogue AP Detection, and Wireless Broadcast Scheduling to further protect your wireless network. The DAP-2690 includes support for up to eight VLANs per band for implementing multiple SSIDs to further help segment users on the network. It also includes a wireless client isolation mechanism, which limits direct client-to-client communication. Additionally, the DAP-2690 supports Network Access Protection (NAP), which is a feature of Windows Server® 2008. NAP allows network administrators to define multiple levels of network access based on individual client’s need.
Multiple Operation Modes
To maximize total return on investment, the DAP-2690 can be configured to optimize network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS) with Access Point, WDS/Bridge (No AP Broadcasting) and Wireless Client. With WDS support, network administrators can set up multiple DAP-2690s throughout a facility and configure them to bridge with one another while also providing network access to individual clients. The DAP-2690 also features advanced features such as Load Balancing and redundancy for fail-safe wireless connectivity.
Network Management
Network administrators have multiple options for managing the DAP-2690 including Web (HTTP), Secure Sockets Layer (SSL, which provides for a secure connection to the Internet), Secure Shell (SSH, which provides for a secure channel between local and remote computers), and Telnet. For advanced network management, administrators can use the D-Link AP Manager II or D-View SNMPv3 management module to configure and manage multiple access points from a single location. In addition, the AP Manager II or D-View software provides network administrators with the means of conducting regular maintenance checks remotely, eliminating the need for sending out personnel to phsyically verify proper operation. Also available is an AP array, allowing the management of a set of network devices as a single group for easy configuration and deployment. In addition, the DAP-2690 has a Wireless Scheduler feature for power saving. With simultaneous dual band functionality, PoE support, extensive manageability, versatile operation modes, and solid security enhancements, the DAP-2690 provides SMB environments with a business-class solution for deploying a wireless network.
* This unit is designed for indoor environments; setting up this unit in outdoor environments may violate local regulatory requirements.
** Maximum wireless signal rate derived from IEEE Standard 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Põhiomadused
Processor
• Atheros AR9344 (600 MHz)
RAM
• DDR2 SDRAM 128 MB
Flash
• SPI Flash 16 MB
Device Interfaces
• 802.11b/g/n 2.4 GHz wireless
• 802.11a/n 5 GHz wireless
• 10/100/1000BaseT PoE (802.3af) LAN port
• RJ-45 console port
• Power DC input
Buttons
• Reset button
LEDs
• Power
• LAN
• 2.4 GHz
• 5 GHz
Antenna
• Two detachable omnidirectional antennas with 4 dBi @ 2.4 GHz gain
• Two detachable omnidirectional antennas with 6 dBi @ 5 GHz gain
Enclosure
• Metal Plenum-rated chassis
Wireless Frequency
• 802.11b/g/n: 2.4 GHz to 2.4835 GHz
• 802.11a/n: 5.15 GHz to 5.35 GHz, 5.47 GHz to 5.85 GHz*
Standards
• IEEE 802.11a/b/g/n
• IEEE 802.3i
• IEEE 802.3u
• IEEE 802.3ab
• IEEE 802.3x
• IEEE 802.3af
Operation Modes
• AP
• WDS
• WDS with AP
• Wireless Client
Network Management
• Web Browser Interface
• HTTP, Secure HTTP (HTTPS)
• Telnet, Secure Shell (SSH)
• D-Link Central Wi-Fi Manager
• D-View Module - Private MIB
• SNMP v1, v2c and v3
• Traffic Control
• AP Array Security
Security
• WPA-Personal/Enterprise
• WPA2-Personal/Enterprise
• WEP 64/128 bit Encryption
• 802.1x
• AES and TKIP
• SSID Broadcast Disable
• MAC Address Control
• Network Access Protection
• Internal RADIUS server
SSID/VLAN
• Support for up to 8 SSIDs/VLANs
Quality of Service (QoS)
• WMM Wireless Priority
Wireless speed**
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n: 6.5 ~ 300 Mbit/s
Transmitter Output Power***
• IEEE 802.11a:
  20 dBm at 6~35 Mbit/s
  19 dBm at 48 Mbit/s
  18 dBm at 54 Mbit/s
• IEEE 802.11b:
  20 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  19 dBm at 48 Mbit/s
  18 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  20 dBm at MCS0-MCS5, MCS8-MCS13
  19 dBm at MCS6/14
  18 dBm at MCS7/15
  2.4 GHz/HT-40:
  15 dBm at MCS0-MCS15
  5 GHz/HT-20:
  19 dBm at MCS6/14
  18 dBm at MCS7/15
  5 GHz/HT-40:
  17 dBm at MCS0-MCS15
Receiver Sensitivity
• IEEE 802.11a:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbit/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -74 dBm at 24 Mbit/s
  -70 dBm at 36 Mbit/s
  -66 dBm at 48 Mbit/s
  -65 dBm at 54 Mbit/s
• IEEE 802.11b:
  -83 dBm at 1 Mbit/s
  -80 dBm at 2 Mbit/s
  -78 dBm at 5.5 Mbit/s
  -76 dBm at 11 Mbit/s
• IEEE 802.11g:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  -82 dBm at MCS0/8
  -79 dBm at MCS1/9
  -77 dBm at MCS2/10
  -74 dBm at MCS3/11
  -70 dBm at MCS4/12
  -66 dBm at MCS5/13
  -65 dBm at MCS6/14
  -64 dBm at MCS7/15
  2.4 GHz/HT-40:
  -79 dBm at MCS0/8
  -76 dBm at MCS1/9
  -74 dBm at MCS2/10
  -71 dBm at MCS3/11
  -67 dBm at MCS4/12
  -63 dBm at MCS5/13
  -62 dBm at MCS6/14
  -61 dBm at MCS7/15
  5 GHz/HT-20:
  -82 dBm at MCS0/8
  -79 dBm at MCS1/9
  -77 dBm at MCS2/10
  -74 dBm at MCS3/11
  -70 dBm at MCS4/12
  -66 dBm at MCS5/13
  -65 dBm at MCS6/14
  -64 dBm at MCS7/15
  5 GHz/HT-40:
  -79 dBm at MCS0/8
  -76 dBm at MCS1/9
  -74 dBm at MCS2/10
  -71 dBm at MCS3/11
  -67 dBm at MCS4/12
  -63 dBm at MCS5/13
  -62 dBm at MCS6/14
  -61 dBm at MCS7/15
Physical Parameters
Dimensions
• 166 x 188 x 36 mm
Weight
• 858 grams (with antennas)
Power Input
• Power adapter (output: 48 VDC, 0.5 A)
• 802.3af PoE compliant
Power Consumption
• 12.95 W
Temperature
• Operating: 0 to 40°C
• Storage: -20 to 65°C
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• FCC
• IC
• CE
• UL
• WiFi®
* Please note that operating frequency ranges vary depending on the regulations of individual countries and jurisdictions. The DAP-2690 may not be supported in the 5.25-5.35 GHz and 5.47-5.725 GHz frequency ranges in certain regions. This product is based on IEEE 802.11n specifications and is not guaranteed to be forward compatible with future versions of IEEE 802.11n specifications. Compatibility with 802.11n devices from other manufacturers is not guaranteed. All references to speed and range are for comparison purposes only. Product specifications, size, and shape are subject to change without notice, and actual product appearance may differ from that depicted herein.
*** Maximum power output varies in each country depending on local power regulations.
Sertifikaadid
Sidustooted
DAP-2690/B1  AirPremier N Simultaneous Dual Band PoE Access Point with Plenum-rated Chassis
Pildid
DAP-2690/B1
Tagantvaade
Paremvaade
Eestvaade
Eestvaade
Failid
Vaadake samuti
