DWA-131EOL EOS
Wireless N nano USB adapter
Kirjeldus
SUPERIOR WIRELESS COVERAGE
D-Link DWA-131 Wireless N Nano USB Adapter provides superior wireless signal for your computer compared to the existing wireless 802.11g technology. This Wireless N adapter is ideal for day-to-day activities such as transferring f les, browsing the Internet, and downloading music. D-Link Wireless N products use smart Antenna technology to transmit multiple streams of data allowing you to receive wireless signals from the farthest corners of your home. Furthermore, D-Link Wireless N technology extends your wireless range, while maintaining compatibility with all your existing 802.11b/g wireless routers and access points.
EASY TO SET UP
The Quick Setup Wizard provides an easy way to setup your USB adapter and the Wireless Manager included with this product helps keep track of all your most frequently accessed networks.
COMPACT AND CONVENIENT
The DWA-131 easily connects your desktop or notebook PC to a wireless network for Internet access and f le sharing. Wi-Fi Protected Setup (WPS) feature enables devices to establish an easy, one-time, single-click connection with an access point or wireless router, eliminating complex encryption codes. WPS also offers advanced security features that are simple and easy to conf gure. With its unique ‘Firefl y’ design and unmatched performance, this ultra-portable USB adapter is an ideal choice for setting up a secure wireless connection.
Põhiomadused
STANDARDS
+ IEEE 802.11n (draft 2.0)
+ IEEE 802.11b
+ IEEE 802.11g
INTERFACE
USB 2.0
FREQUENCY RANGE
2.4GHz to 2.4835GHz
ANTENNA
PIFA antenna
SECURITY
+ WEP
+ WiFi Protection Access (WPA & WPA2)
+ WiFi Protection Setup
+ PBC/PIN
LED
Link/Activity
CERTIFICATIONS
+ FCC Class B
+ IC
+ Wi-Fi
+ CE
+ C-Tick
+ Windows Vista certifed
OS SUPPORT
Windows 2000, XP, Vista (32/64 bit)
Sertifikaadid
Sidustooted
DWA-131  Wireless N nano USB adapter
Pildid
DWA-131/A1
Eestvaade
Eestvaade
Failid
Vaadake samuti
