Kiirotsing
Toote omadused:
Pan & Tilt Wi-Fi Day/Night Camera
Põhiomadused:
Camera  Hardware Profile
• 1/5” VGA progressive CMOS sensor
• 8 meter IR illumination distance
• Minimum illumination: 0 lux with IR LEDs on
• Built-in Infrared-Cut Removable (ICR) Filter module
• 4X digital zoom
• Lens: Fixed length 2.2 mm
• Aperture: F2.4
• Angle of view:
  (H) 57°
  (V) 42°
  (D) 68°
• Exposure Time: 1/15 to 1/15000 sec.
• Built-in microphone
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Adjustable brightness, saturation, contrast
• Flip & mirror
• Pre-event snapshot/recording
Video Compression
• MJPEG multi-streaming
• JPEG for still images
Video Resolution
• 640 x 480 at frame rates up to 15 fps; 320 x 240, 160 x 112 at frame rates up to 30 fps
• JPEG Quality: Very Low, Low, Medium, High, Very High
Video Features
• AGC
• AWB
• AES
Audio Compression
• PCM
Connectivity
• 10/100 BASE-T Ethernet port
• 802.11n/g/b wireless
Pan Range
• -170° to +170° (total 340°)
Tilt Range
• -25° to +95° (total 120°)
Angular Velocity
• 16° per second
Step Setting
• Pan 1°/2°/3°/4°/5°(default)/10°/15°/20°/25°/30°/per click
• Tilt: 1°/2°/3°/4°/5°(default)/10°/15°/20°/25°/30°/per click
Network Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP Client
• NTP Client (D-Link)
• DNS Client
• DDNS Client (D-Link)
• SMTP Client
• FTP Client
• HTTP Server
• PPPoE
• UPnP Port Forwarding
• LLTD
Security
• WPS
• WEP
• WPA-PSK, WPA2
• HTTP digest encryption
• Password authentication
System Requirements for Web Interfaces
• Operating system: Microsoft Windows XP/Vista/7/8, Mac OSX
• Browser: Internet Explorer 7/Firefox 12/Safari 6/Chrome 20 or higher with Java enabled
Event Management
• Event notification and uploading of snapshots/video clips via e-mail (SMTP) or FTP
• Motion Detection
Remote Management
• Configuration accessible via web browser
Mobile support
• mydlink Lite app for iOS and Android
• mydlink+ app for iOS and Android
Physical Parameters
Weight
• Device: 292.8 grams
• Stand: 60.8 grams
Power
• 5 V DC 1.5 A,  50/60 Hz
Power Consumption
• 4.8 watts
Temperature
• Operating: 0° to 40°C
• Storage: -25° to 70°C
Humidity
• Operating: 20% to 85% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Dimensions
• 55 x 43.1 x 95 mm (Camera only)
• 58 x 101.4 x 128.8 mm (Including mounting bracket)
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
