DES-3028EOL EOS
Hallatav 2 taseme kommutaator, 24 x 10/100 Мbit/s porti + 2 x 1000BASE-T porti + 2 x 1000BASE-T/SFP kombo porti
Kirjeldus
  • High Port Density 10/100 Switch
  • Optimized for Low Cost & Rich Features
  • 4 Gigabit Uplink Capacity
  • 4K VLAN & ACL Support
  • Secure/Effective Management with RADIUS/TACACS+,Single IP Management, SSH/SSL Support
The DES-3028 switch is a managed Layer 2 Ethernet switch designed as the premium devices in the entry-level network management category. The switch offers very rich functions to let SMB and even enterprises set up a secure and effective departmental network at affordable cost. Outstanding features include high port densities, 4 Gigabit uplinks, comprehensive network security, granular bandwidth control and extensive network management. With DES-3028, businesses can now optimize their networks at both the function and cost levels for maximum results.
The DES-3028 has 24 Ethernet ports in low profile rack-mount case. The switch is equipped with 2 Gigabit uplinks, with the SFP supporting both fiber Gigabit and 100BASE-FX fiber connection for specific applications.
The DES-3028 supports many security features including Access Control List (ACL), 802.1X Port-Based/MAC-Based Access Control, 802.1X Guest VLAN, and RADIUS/TACACS+ authentication. To prevent malicious attack and virus/worm affection from overwhelming the switch with unnecessary workload, the DES-3028 provides D-Link Safeguard Engine and CPU Interface Filtering functions to increase the switch's reliability and availability.
To enhance network resilience, the DES-3028 provides Spanning Tree protocols, including 802.1D, 802.1w and 802.1s for redundant bridge paths. 802.3ad Link Aggregation provides the aggregated bandwidth between switches or server, For Quality of Service (QoS), it supports 802.1p Priority Queues and packet classification based on TOS, DSCP, MAC, IPv4, VLAN ID, Protocol type, User Defined Packet Content, enabling Internet voice, video and streaming media applications to run smoothly.
Network administrators can define throughput levels for each port to manage bandwidth. The bandwidth control feature provides fine granularity with the ability to define limits down to 64Kbps segments. Broadcast storm control can reduce the level of damage that a virus attack can do to the network. The switch provides IGMP snooping to control multicast transmission, and port mirroring to facilitate diagnostics.
The DES-3028 supports standard-based management protocols such as SNMP, RMON, Telnet, web-based GUI, SSH/SSL security authentication and DHCP Relay Option 82. With DHCP auto-configuration, the administrator can pre-set configurations and save them in a TFTP server; individual switches can boot their IP from the server and load in the pre-set configurations. D-Link Single IP Management simplifies and speeds up management tasks, allowing multiple switches to be configured, monitored and maintained from any workstation running a web browser through one unique IP address. A virtual stack of the DES-3028/3052 switches can be managed as a single object, with all units identified by a single IP address.
Põhiomadused
 Liidesed
  • 24 x 10/100Base-TX porti
  • 2 x 10/100/1000Base-T porti
  • 2 kombo porti 10/100/1000Base-T /SFP
  • Konsoolport RS-232
    Tootlikkus
  • Kommutaatori mahtuvus: 12.8 Gbit/s
  • 64-baitilie pakettide ülekandekiirus: 9.5 Mpps
  • МАС-aadressite tabel: 8 К
  • SDRAM CPU jaoks: 64 МB
  • Paketide bufferi suurus: 4 МB
  • Flash-mälu: 8 МB
  • Jumbo-freimid (2048 baiti tagged jaoks, 2044 baiti untagged jaoks)
    Indikaatorid
  • Toide
  • Konsool
  • Link/Activity
  • Kiiruse indikaator
  • Teise taseme funktsioonid
  • IGMP Snooping v1, v2 (max 256 gruppi)
  • IGMP Snooping Fast Leave
  • 802.1D Spanning Tree
  • 802.1w Rapid Spanning Tree
  • 802.1s Multiple Spanning Tree
  • BPDU filtering iga pordi jaoks
  • STP Loopback Detection
  • 802.3ad Link Aggregation:
    8 porti igas grupis / 6 gruppi ühel seadmel
  • Portide peegeldamine (One to One, Many to One režiimid)
  • Jumbo-freimide toetus
    VLAN
  • 802.1Q
  • VLAN staatiliste gruppide arv – 4К
  • VLAN dünaamiliste gruppide arv– 200
  • GVRP
    Teenuse kvaliteet (QoS)
  • Prioriteedi järjekorrad 802.1p
  • 4 prioriteedi järjekorda 802.1p
  • WRR toetus / Strict mode
  • Pakettide klassifitseerimine
    • pordi number
    • VLAN ID
    • TCP/UDP pordi number
    • МАС-aadress
    • IP v4
    • 802.1р prioriteet
    • TOS
    • DSCP
    • protokolli tüüp
    • paketi sisu
    Ligipääsu juhtimine
    (max 256 profiili / reeglit)
  • Mitmetasemelised ACL:
    • pordi number
    • VLAN ID
    • 802.1p prioriteet
    • МАС-aadress
    • IPv4
    • DSCP
    • protokolli tüüp
    • Paketi sisu
    • Aeg
    Võrku ligipääs / Turvalisus:
  • RADIUS/TACACS+ autentimine ligipääsu juhtimiseks
  • RADIUS kasutajatunnuste loomine
  • Port security funktsioon (max 16 МАС-aadressite kirjet pordile)
  • Ligipääsu juhtimine 802.1х portide baasil
  • Ligipääsu juhtimine 802.1х МАС-aadressite baasil
  • 802.1х Guest VLAN
  • SSH v.1, v.2 / SSL v.3
  • CPU Interface Filtering
  • Liikluse segmenteerimine
  • Broadcast tormi kontroll
  • D-Link Safeguard Engine
    Ülekanderiba juhtimine:
  • Kiiruse piiramine:
    kuni 2 Мb: 64 Кb sammuga
    kuni 100 Мb: 1 Мb sammuga
    rohkem 100 Мb: 8 Мb sammuga
    Juhtimine
  • D-Link Single IP Management (SIM) v. 1.6
  • Web-liides
  • Käsurea liides (CLI)
  • Telnet server / klient
  • TFTP klient
  • SNMP v.1, v.2c, v.3
  • RMON v.1, v.2
  • BootP/DHCP-klient
  • SNTP
  • SYSLOG
  • Dual image
  • Pordi kirjeldus
  • Graafiline GUI Web- liides liikluse monitooringu jaoks / CPU
  • SNMP trap on MAC notification
  • DHCP Auto Configuration
  • DHCP relay
  • DHCP relay опция 82
  • SMTP klient (teatised e-maili)
    MIB toetus
  • MIB II (RFC 1213)
  • Bridge MIB (RFC 1493)
  • SNMP v2 MIB (RFC 1907)
  • RMON MIB (RFC 1757, 2819)
  • RMON v2 MIB Probe config group (RFC 2021)
  • Ether-like MIB (RFC 1643, 2358, 2665)
  • 802.1p MIB (RFC 2674)
  • IF MIB (RFC 2233, 2863)
  • RADIUS Authentication Client MIB (RFC 2618)
  • RADIUS Accounting Client MIB (RFC 2620)
  • Ping & TRACEROUTE MIB (RFC 2925)
  • Private MIB
    Sertifikaadid
    Sidustooted
    Pildid
    DES-3028/A
    Eestvaade
    Tagantvaade
    Failid
    Vaadake samuti
